Go to Post While at kickoff I asked Woodie if there were any concerns about missed shots at the center goal hitting the operators or the controls. He handed me a ball and told me to throw it at him as hard as I could... How many times does an opportunity like that come up? - Barry Bonzack [more]
Unread 27-02-2011, 20:02
J93Wagner J93Wagner is offline
Where'd all the time go?
AKA: Jonathan Wagner
no team (Formerly N.E.W. Apple Corps)
J93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to behold
Re: Unknown Performance Issues with Inventor
I'll admit it, I also want a solution to how to get around it, and although when I encountered it, it wasn't so painfully slow (only about 5-10 second delay time), it was indeed very annoying and frustrating. So, it's for that reason, or a similar one anyway why I would rate Inventor 2010 better than 2011 (although I would say it is pretty close, 2011 improved on 2010 a lot in getting around to what needed to get done).
/rant
But anyway, you mentioned that you constrain every bolt and washer you can. Part of the problem might be because Inventor tries to render every single part before moving. While I doubt it is the major factor as to the slowing of your computer, it might help a little bit and get things done more efficiently.
Otherwise, try to do everything you possibly can in sub-assemblies to make the chunks you have to work with as small as possible, thus the least amount of rendering that has to be done.
My personal favorite quote: "There is nothing better than being proud of the things you love." -Sean "Day[9]" Plott
Last edited by J93Wagner : 27-02-2011 at 20:06. Reason: Realized how something sounded :shame on myself:
Unread 28-02-2011, 21:03
Solidstate89's Avatar
Solidstate89 Solidstate89 is offline
CAD Leader
AKA: AK-Fo'7
FRC #1507 (The WARLOCKS)
Solidstate89 has a spectacular aura aboutSolidstate89 has a spectacular aura about
I am starting to come to the realization that we perhaps somehow used too few sub assemblies. We've done exactly what we've done in years past, however I guess with the increased complexity of Inventor 2011, we had to re-adjust how we put our assemblies together. Adjusting the Level of Detail did nothing, and previous years assemblies open just fine.
It must be some combination of incorrect/conflicting constraints and the sheer number of them. I just didn't think that even with that it could bring hardware like mine to its knees.
I'll have to keep a closer eye on this kind of issue next year, so hopefully we can catch it before it ever even becomes an issue.
Thank you to everyone who assisted me.
Unread 02-03-2011, 22:35
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
If you are at the Championship in St Louis, drop by the Autodesk booth and we can have a longer discussion on this topic.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 03-03-2011, 18:30
CAD Leader
AKA: AK-Fo'7
I'm sorry to say that I won't be able to make it to St. Louis with the rest of my team due to my job.
Unread 10-03-2011, 00:06
pmax's Avatar
pmax pmax is offline
AKA: Peter Maxfield
pmax is a name known to allpmax is a name known to allpmax is a name known to allpmax is a name known to allpmax is a name known to allpmax is a name known to all
A couple thoughts come to mind:
- Try suppressing _all_ constraints (easy to do if you change to Model view at the top of the browser), to see if indeed conflicting constraints are the culprit. If you already have a mix of suppressed constraints and do not want that lost, then either close and do not save once you have investigated, or Undo.
- LODs should help, but if you are seeing such dramatic performance issues, I do not suspect the memory is a problem.
Also, LODs are designed to respect constraints, even if the component is suppressed, so if the issue is indeed constraints, the LODs will not help.
- Assembly Features can cause performance issues if used too liberally. Generally I recommend keeping them in subassemblies as best possible, instead of high up in top assemblies.
- Are you using a Space Mouse? We have seen driver issues in the past, causing just this kind of multi-minute delays.
Regards,
Pete
Autodesk
www.autodesk.com/first
Unread 10-03-2011, 16:12
JCharlton's Avatar
JCharlton JCharlton is online now
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
How common is this? I've been looking at getting one of these for Inventor. Thanks for any advice.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 10-03-2011, 19:57
CAD Leader
AKA: AK-Fo'7
I do commonly use a Space Mouse, yes. Started using at when I got hired at my place of employment about 6 months ago and haven't been able to do 3D Modeling without it since.
However I've set the driver on my desktop to only start when I activate it. It will not turn on automatically. And due to just how slow the assembly was, it wasn't worth even plugging in my space mouse and using it. With that being said, for all the sub assemblies I never ran into performance issues even when using the Space Mouse. I'm more and more believing it was all those faulty constraints. I plan to keep out a better eye for those next year.
And to you JCharlton, I would highly recommend one if you're constantly working wit 3D CAD or any other form or 3D Modeling program. It is an absolute god-send. It took me about a week, maybe a week and a half to get used to, and like I said in my previous paragraph - I just can't do 3D modeling work without it anymore. At the beginning of this season I even purchased a 3D Connexion Notebook Spacemouse so I could use it with my laptop when I would head to the high school after I got out of work.
