Go to Post I would not want the task of devising a system that 50,000 very smart people try to outwit. - texarkana [more]
  #31   Spotlight this post!
Unread 03-03-2011, 08:25
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Re: Fixing Burnt Motors
Has anyone found an equivalent part?
We have a couple of motors that we would like to repair.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
  #32   Spotlight this post!
Unread 03-03-2011, 09:36
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Torbots, did that motor ever 'release the magic smoke' or smell burned?
We smoked a few last night, but they were minor incidents, and appear to still run.
  #33   Spotlight this post!
Unread 08-03-2011, 16:57
Torbots 1197 Torbots 1197 is offline
Chief Tormentor
FRC #1197 (TorBots)
Team Role: Communications
Torbots 1197 is an unknown quantity at this point
The motor we pulled the photographed inductor from did not smell burned nor did it have any visual release of "magic smoke". We have noticed with some other motors that even though some magic smoke was released they continued to run but at a degrated level. Some guesses within our shop is that some of the inductor's windings fused together, allowing current to still flow through the motor.
  #34   Spotlight this post!
Unread 08-03-2011, 19:04
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Has anyone gotten official confirmation of what specific part numbers/vendors we're allowed to use for the inductors? The most common I've heard of is Mouser's 9310-26-RC, but I confess I don't know enough electrical theory to confirm anything.
  #35   Spotlight this post!
Unread 09-03-2011, 09:56
None #0612
That inductor has only a 0.28 amp current rating. I doubt it would last long.
  #36   Spotlight this post!
Unread 09-03-2011, 21:51
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Your report just adds to the mystery of the smoke. Here is my current theory about the failure of Tetrix motors. These motors have no ventilation or builtin fan cooling. Over current in the armature coils can cause them to overheat. Do this often enough and the shellac (like) insulation will melt (and smoke) in places and short some wires together. This will lower the impedance of the coil and increase its current demand. That is, the motor still runs, but uses more current to do it. More current means more possibility of insulation melting and shorting. Eventually so much current is required by the motor, that the inductor can no longer pass it without failure by overheating.
I suspect that the smoke in your case came from the armature and that your motor is still usable even though degraded as you report. Melting insulation does not necessarily cause windings to short every time. It is just that you cannot continue to melt insulation without consequence for very long. The difficulties we're having with this motor are not mirrored by the way they are used in the FTC because the FTC is using them via motor controllers with electronics. Perhaps the GDC envisioned more robot-like minibots climbing those poles with more electronics than is common in this year's machines. I think that would have been kinder to the motors, at least.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
  #37   Spotlight this post!
Unread 09-03-2011, 22:57
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
There is a coil inside the motor to prevent electrical noise. That coil is only good to handle about 500mA worth of DC current. With the way were using them, we are easily exceeding that current rate of that little guy. Therefore it goes up in smoke, burning itself open. The motor wires themselves are heavy enough to handle that power, or at least the 3-4 second runs they have to go through.
Mouser has a 3.9uH that has a current rating of 640mA made by Bourns.
I don't have the part number now, I have it at work. - and its pretty close to the same size as the orignal part. Only major difference is instead of the body being green this one is blue - but the color bands are all the same.
  #38   Spotlight this post!
Unread 11-03-2011, 07:47
Darrin,
The inductor is more like the 900 ma version. Those are non-stock items at Mouser the last time I looked. Still under rated for our service with a motor that stalls at 7.5 amps.
  #39   Spotlight this post!
Unread 15-03-2011, 10:04
philso philso is offline
FRC #2587
When choosing a replacement inductor, one should take into account the series DC resistance, or DCR on many of the data sheets from the manufacturers.
I measured the DC resistance of an unburnt inductor at 0.2020 Ohms and 0.1991 Ohms with a second meter. I used two brand new (one still had the protective plastic on the display) Fluke 8845A 6 1/2 Digit bench DVM's connected in the 4-wire mode to cancel the resistance of the meter leads. These meters are accurate to 0.006 Ohm on the range used. For comparison, the resistance across the metal back plate of the motor measured 0.0050 Ohms.
The power connection tabs on the motor had been broken off by rough handling and the inductor showed no signs of turning brown in the middle.
  #40   Spotlight this post!
Unread 15-03-2011, 13:09
AKA: Darrin Munter
This is what I found: 77F3R9K-RC from Mouser. This has a MAX DC resistance of .37 ohms, can handle 640 mA of current. And is the exect same size of the old ones.
Al, I think if you went with one rated at 900 mA it would be larger than the orignal.
Here is an orginal burnt one and the new one that I got in today.
Name:	IMG_0484 (Small).jpg
  #41   Spotlight this post!
Unread 15-03-2011, 13:17
Darrin,
The non-stock item I was looking at was the exact same package size in the 900 ma+ range.
  #42   Spotlight this post!
Unread 15-03-2011, 17:38
scooperman's Avatar
scooperman scooperman is offline
FRC #1523
scooperman is an unknown quantity at this point
Lots of smoke suggested that this motor would never make full torque again, so I didn't mind trying something different when repairing it. I picked a higher-current rated 3.9uH inductor, J.W.Miller (now Bourns) p/n 5800-3R9-RC, got it from Digi-Key, their number is M8276-ND. Its rated current is 1.28A, at which it will heat up 35C. Physically this part is larger than the original, but there is just enough room if you mill the groove/divot in the plastic, make the groove a bit longer. I got the motor to run again, but sure enough it uses a lot more current than a new motor even with no load. So this motor won't be going on any bots again.
  #43   Spotlight this post!
Unread 21-03-2011, 10:30
Woodie Flowers Award
Bill Beatty Bill Beatty is offline
#0071 (Team Hammond)
Bill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond repute
I heard that at the Boilermaker Regional they were openly removing the choke in the mini bot motor. There was even a guy who was doing it for anyone who brought a motor to him. He said that it did not improve the motor performance and therefore was perfectly legal to take it out and replace it with a piece of wire.
Has anyone heard anything more on this subject? Although our sampling is very small, we have seen a significant improvement with the choke shunted out.
"Mr. Bill" Beatty
  #44   Spotlight this post!
Unread 21-03-2011, 11:04
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
"Mr. Bill" Beatty
I would be extremely interested in this as we have repaired several motors with the most equivalent inductor we could find and have noticed significant power decrease, as well as the motor only running for about 30 seconds before burning up again.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
  #45   Spotlight this post!
Unread 21-03-2011, 12:12
Bill,
I had made that recommendation to the GDC to eliminate the expense of replacing motors. However, the official response was to allow repairs with equivalent replacement parts only. As I read that, removal is not legal.
R55..
M. Devices may be repaired, provided the performance and specifications of the component after the repair are identical to those before the repair.
