Go to Post Unsure if I'll get it to work, but that's no reason to not try. - DonRotolo [more]
Unread 03-03-2011, 09:12
GaryVoshol's Avatar
Cogito ergo arbitro
Exclamation Team Update #16 - EMERGENCY
Team Update #16 has been posted: http://www.usfirst.org/uploadedFiles...pdate%2016.pdf
It affects RED and YELLOW cards under <G32> and <G33>, and removes a potential "one-move-win" strategy in elminations:
It has come to our attention that some TEAMS have concluded a ‘one move win’ is possible under the following scenario:
A blue ALLIANCE ROBOT is in the blue ZONE. A second blue ALLIANCE ROBOT is outside the ZONE, but in the general vicinity. A ROBOT from the red ALLIANCE, exiting its LANE, crosses near the second blue alliance ROBOT. The second blue ALLIANCE ROBOT intentionally pushes the red ALLIANCE ROBOT in to the blue ZONE. The red ALLIANCE ROBOT contacts the first blue ALLIANCE ROBOT. This would result normally result in a YELLOW CARD for the second blue ALLIANCE ROBOT and a RED CARD for the red ALLIANCE ROBOT per Rule <G32>. However, if this were to occur during an elimination match, this would result in the entire red ALLIANCE being disqualified per Rule <T13>, and a ‘one move win’ by the blue ALLIANCE.
Referees will be instructed that an attempt to win a MATCH in this way, by the blue ALLIANCE in the scenario above, would be considered particularly egregious behavior under Rule <T09>, resulting in a RED CARD for the blue robot and thus a disqualification of the entire blue ALLIANCE under Rule <T13>. As any attempt at this behavior would necessarily precede contact, in the scenario above, of the red ALLIANCE ROBOT with the blue ALLIANCE ROBOT in the blue ZONE, the blue ALLIANCE disqualification would take precedence over the red ALLIANCE disqualification, and the red ALLIANCE will be declared the winner of the MATCH.
(since 2004)
Unread 03-03-2011, 09:17
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
Re: Team Update #16 - EMERGENCY
Not exactly an emergency, unless your strategy revolves around intentionally trying to get other teams disqualified.
Zip-ties, hot glue, and duct tape.
2008 New York City Regional Champions - (41/555/1989)
2009 Brunswick Eruption 8 Finalists - (1989/56/1807)
2010 PARC XIII Champions - (25/341/1989)
Over The Bump
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Thanks for the notice. I am glad they decided to eliminate the possibility of this happening before qualifications started at the least. Although the way of making sure this is happening to prevent it is going to be tough on referees.
Unread 03-03-2011, 09:38
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
I'm glad they fixed this. It should have been done sooner though.
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 03-03-2011, 09:44
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
I find it disturbing that there is even one participant who might consider adopting such a tactic.
Thank you for the clarification, GDC.
Warren B
Pool Noodles. They're not just for bumpers anymore.
Unread 03-03-2011, 09:48
Chris is me's Avatar
AKA: Pinecone
I could tell bad things were going to happen when they added the exception to the "cannot cause a penalty" rule.
Unread 03-03-2011, 10:21
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
This has been discussed here more than a little bit. However long it took, I am very glad that they changed this rule. When they first announced the interpretation they are now changing it was obvious to me that it could be a real problem. Any rule that allows you to be disqualified because of the actions of your opponents has a great potential to be abused.
If I am reading it correctly, I actually think the way it is now worded strikes a good balance. If I try to push the red robot into my zone in order to disqualify them, I get disqualified. If the red robot is trying to block me from scoring in my zone and as a result is pushed into another blue robot then the red robot is disqualified.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 03-03-2011, 10:40
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
And a ref who may not even be looking when the incident happens will decide which team gets disqualified.
I think it's a horrible rule situation. The GDC needs to get it's act together, come up with a set of rules for a game at the beginning of the season, and not spend the rest of the build season changing the rules to try to get teams to play the game the way they "think" it should be played.
They now have rules for Logomotion that depend on a referee deciding whether an alliance is working together to blockade the field (G48-C), and now another one for a referee to decide whether a team intentionally pushed one robot into another.
2007 - Rookie All Star - Bayou Regional (1858 - Tyborgs)
2009 - Rookie All Star - Bayou Regional (2992 -Prometheus)
2010 - Champions - Bayou Regional (2992 -Prometheus)
2012 - Finalist - Bayou Regional (2992 - Prometheus)
team2992.com/design.php
Unread 03-03-2011, 10:47
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
The original "cannot cause a penalty" rule has been an exception to the other rules for a while...then they added an exception to it....now they added an exception to that....
So we now have an exception to an exception to an exception. Who is lawyering things now?
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 03-03-2011, 10:48
ATannahill ATannahill is offline
AKA: Alex Tannahill
I think the GDC just saw Inception.
- Arizona North
Unread 03-03-2011, 11:18
AKA: Pinecone
I was referring to the exception from the cannot cause a penalty rule.
Unread 03-03-2011, 11:25
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Good to know they don't want anyone trying that move. It's better to make it explicit in this manner than sort it out later during an event.
But what's with the precedence implied in the last sentence? If you got your alliance disqualified, but the other alliance got disqualified first, you win? The rules previously implied nothing of the sort—both alliances would be disqualified, and there would be another match—so this is a change to "The Tournament" that should be specified. (It's one thing to give teams a heads-up that something will be considered an aspect of an existing rule; it's another to change the rules without adding the relevant language to the rulebook.)
And what happens if the DQ was for another perfectly valid reason? Or what if both teams use the same banned strategy? Is the "necessarily precede contact" clause an implication that if there is an order of events causing alliance disqualifications, only the first one counts toward the final resolution of the match?
And what about the qualifying rounds? My initial impression is that this changes nothing, even in the situation where a robot attempts this strategy to disqualify the last undisqualified member of the opposing alliance. (The fact that it's in the eliminations seems to be a fundamental part of the scenario.) In that case, both robots get disqualified (instigator and victim), and the remaining alliance members on the instigator's alliance get the benefit of 5.3.6: their own score as RS.
Unread 03-03-2011, 11:30
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
I hadn't thought of that strategy, and probably would never have suggested its implementation. Winning is winning, however.
Regardless, always nice to have FRC more based on robot merit than strategies aimed at disqualifying opposing alliances!
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 03-03-2011, 11:54
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Oy. I knew this was possible when I read some of the early defensive posts, but I never brought it up to my team since I never wanted them to even think this way in terms of building a robot. It's a good thing the GDC addressed it.
[In general, not completely related to this update] It seems to me that the rules this year could add some severe conflicts of interest if the referees have any affiliation with teams on the field or have a bias based upon a team's history. Who's chasing who? who backed off first? Was something intentional? Did that minibot deploy a fraction of a second too early? They're all subjective and at the mercy of referee interpretations. I don't think it would be a big deal except that the subjective parts are all getting more visibility. At this point I think all we can do is hope that an alliance in elims doesn't appear to try it.
GitHub
Unread 03-03-2011, 16:25
Molten's Avatar
AKA: Jason
I was actually referring to FIRST lawyering the rules, not you. Sorry for the confusion.
