Go to Post I don't like to tempt the gods of inspection on items like this. - MrRoboSteve [more]
Unread 02-03-2011, 22:42
dcorneail's Avatar
dcorneail dcorneail is offline
FRC #1684 (Magic Smoke)
dcorneail is an unknown quantity at this point
Compressor
Were using the old compressor and were wondering if we can mount it upside down?
Unread 02-03-2011, 22:44
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
Re: Compressor
I know we have on experimental robots, but they never ran through a competition season. I don't see why not though.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 02-03-2011, 22:45
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Re: Compressor
Most compressors use internal oil to lubricate the workings. They depend on gravity to keep the oil at the bottom where it is needed. Thus, putting the compressor upside down is not be a good idea. And with a replacement cost of near $400, it might be expensive.
Unread 02-03-2011, 22:53
dman14 dman14 is offline
AKA: Darren Stahl
FRC #4783 (FRC #1305 Alumni)
dman14 will become famous soon enoughdman14 will become famous soon enough
Re: Compressor
We had our compressor mounted upside down all of last year, (with very minimal usage as the only piston was a small 3/4" bore) but had no problems, if you do mount it upside down make sure to lock it in place or at least check the bolts often, as the vibrations and weight of the compressor tend to loosen them.
Note: Don't take my experience as a guarantee that it will work, because as stated we only used it for a single 2" stoke 3/4" bore that was fired maybe 10 times per match at most. As such, on time was minimal at best (other than on startup).
Unread 03-03-2011, 07:00
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Compressor
We ran our compressor upside down all last year all through competition season and two off season events without any problems at all.
Unread 03-03-2011, 10:59
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
Re: Compressor
For what I can see the old compressor is a Thomas WOB-L type, from my experience with the larger versions of these there should be no problem running them upside down.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 03-03-2011, 11:32
Re: Compressor
You may run the compressor upside down but the rubber mounts are meant to be in compression. If you choose to isolate the compressor from the frame (recommended), you will need isolators that are designed for that use.
Unread 03-03-2011, 14:26
R3P0's Avatar
R3P0 R3P0 is offline
Always InTeNsE!
AKA: Jamie Robinson
FRC #1504 (Desperate Penguins)
R3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of light
Send a message via ICQ to R3P0 Send a message via AIM to R3P0 Send a message via Yahoo to R3P0
Re: Compressor
We had ours mounted upside down last year. No issues
Time is irrelevant at the speed of light.
