Go to Post The strive for the Chairman's award is by far more important than the award. - Pavan Dave [more]
Unread 03-03-2011, 13:17
tdressel tdressel is offline
FRC #1111
tdressel is an unknown quantity at this point
"Versions" at Competition - it's 03/03/2011 - what are the required versions?
I was checking the Team Updates (http://www.usfirst.org/roboticsprogr...nt.aspx?id=450) and realized I hadn't checked software updates (http://www.usfirst.org/roboticsprogr....aspx?id=18758) in a while. I've missed a few. Was wondering if you all can confirm my list:
1. Team Updates - 16 and counting as of 03/02/2011
2. Cypress IO Firmware Update: still FRC_IO.v2.hex?
3. All teams (LabVIEW/C++/Java) - Utilities - FRC2011Utilities.zip (01/08/11)
4. All teams (LabVIEW/C++/Java) - Driver Station - FRC2011DriverStation2_27_11Update.zip (02/28/11 - 5 days ago!!!)
5-a. LabVIEW Teams - FRCLabVIEWUpdate3.2for2011.zip (02/16/11)
5-b. C++ Teams - Not sure but people should add here
5-c. Java Teams - Not sure but people should add here
6. Version of firmware that should be on cRIO: ??? not sure.
Ted Dressel, Mentor, Team 1111
Unread 03-03-2011, 13:42
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: "Versions" at Competition - it's 03/03/2011 - what are the required versions?
Now THIS is a very good thing to do - thank you!
5-b. C++ Teams - Version 2262 - Page Link
5-c. Java Teams - Version 4.14 - Page Link
6. cRIO Image: v28 - Page Link
Unread 03-03-2011, 14:41
This is optional, the previous version (from beginning of January) can be used also.
Unread 03-03-2011, 16:16
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
4. All teams (LabVIEW/C++/Java) - Driver Station - FRC2011DriverStation2_27_11Update.zip (02/28/11 - 5 days ago!!!).
I saw a passing reference to this update in another thread here but I have seen no official announcement from FIRST on this... and there is no description on the update page to indicate what was changed. Anyone heard anything more about this?
Unread 03-03-2011, 16:29
All I know is the vague description jhersh posted yesterday: it is intended to "ease" configuration of the driver station computer's IP address.
Unread 06-03-2011, 19:46
The less vague description is that the 1-05-11 DS used add and delete to update IP settings for the wifi and LAN NIC. This was done so that computers with multiple LAN cards, or perhaps multiple wifi cards could more easily swap configuration. The DS would add the IPs it needed, and would later delete them if the team number changed or if the NIC changed.
The new DS 2-28-11 uses set to update the IP values. If a NIC is no longer being used, the DS sets the IP to DHCP.
The Jan. edition generally works fine, but on certain laptops has a tendency to collect IP addresses on the NICs. This can be seen using "netsh interface ip show ipaddresses" for Win7, and show config for XP. You can also view them using the IPV4 adapter settings and clicking on the Advanced tab.
If a DS has multiple 10.xx.yy.zz addresses assigned to the LAN, this can cause the DS to fail to connect to the field. The DS will look for responses on one IP and the field may send them on another.
If your laptop connects to the field with 1-05-11, your IPs are good, or you got lucky. If it doesn't connect to the field, verify you do not still have the 10-22 version from the initial classmate image, check for the correct IP address and only one IP address. If you update to the 2-27 edition, it does this for you.
Other precautions you may want to take with your DS at the event -- especially if this is your own laptop ...
* Disable the wifi adapter. It will save power, cut down on traffic, and prevent the laptop from joining any "trusted" networks that are in the profile cache.
* Relax the firewall settings, or disable the firewall entirely.
* Ensure that you have a Driver account and are logged into it when you go to the field. If your DS has a title bar, the account is not Driver.
Greg McKaskle
Unread 06-03-2011, 20:07
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
We have this (kind of) mirrored on our code wiki at http://code.google.com/p/chopshop-16...ForCompetition, but this is REALLY good to have, and important to know. We thought we had some problems at GSR because we hadn't heard anything about the update, and somehow inspection didn't bring it to light.
GSR Dean's List Finalist 2011
Unread 28-03-2011, 14:18
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
Per Ken Mitchell, FIRST NorCal Assistant Regional Director and FTA Wizard, the Drivers Stn v02.27.11 is mandatory for the Silicon Valley Regional, email dated March 23. Ken worked a lot of connection problems at the Sac/UCD Regional.
Maybe we'll get the Tuesday Team Update about this, and I'm not going to squabble about its source.
> Please Read Team Update #19 (Attached) and update your cRio and DS code
> If you do not have Drivers Station version 02.27.11 and cRio version 28 or
> higher you will be TOLD to update it.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
Unread 28-03-2011, 22:46
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
I'm right there with you. I was FTAA at the WPI regional and almost every connection issue we had on practice day seemed to be with that version. Once teams updated it, 95+% of the issues were resolved. I would require it at any regional I attend, either as an inspector or FTA(A).
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
