Go to Post Unfortunately, there's no special type of transmission that will magically get you past defense. The best way to deal with defense is to practice, regardless of gearing. - connor.worley [more]
Unread 03-03-2011, 15:09
JoelC JoelC is offline
The Game
FRC #1251 (TechTigers)
JoelC is an unknown quantity at this point
Need Help With Wire Recoiling
Hi! I'm from team 1251. We have an elevator system on our robot but we have an issue with cables. The issue is that when we move our elevator up, the cable tend to "slack" on both ends. Is there a way to recoil the cable as it goes back down? Or perhaps a way to keep it tensioned on either one or both end?
Unread 03-03-2011, 15:44
Re: Need Help With Wire Recoiling
The Igus Energy Chain in the Kit of Parts might be useful.
Unread 03-03-2011, 15:59
The Game
We've given the Igus Energy Cable a try but we have two stages to our elevator. As well, we have tried to attach a second Igus Energy Cable but it is still very flimsy and very hard to mount after it has past the first stage. Is there any other way that would be easier to mount?
Unread 03-03-2011, 16:11
1) Tie a long piece of surgical tubing to a "stationary" point on the robot.
2) Tie the other end of that piece of surgical tubing to some point on the cables you need to keep controlled.
3) Adjust tension and placement of surgical tubing as needed.
It also helps to keep the cables all together in one bundle; this adds a great deal of stiffness.
Unread 03-03-2011, 16:27
The Game
Thanks EricH, we tried it out but we still had an issue with slack. Though, we found our solution. What we did is we put the elevator at its highest point. On the highest point of the first stage, we put it along the side. Then we measure how much cable it would take to go from the first stage to the bottom. Now, when the arm comes down, the wire comes down in a sort of U-shape. It is nice and straight when it is at its highest point and its lowest point. Thank you for the help Alan and Eric! ^^
Unread 15-03-2011, 16:32
scooperman's Avatar
scooperman scooperman is offline
FRC #1523
scooperman is an unknown quantity at this point
Not sure if you can see them in this video, this was a mast experiment which used one motor and two cables.
http://www.youtube.com/watch?v=zGf9OHUmHHw
At the ends of each cable there was a spring, those springs do take up a bit of slack but primarily they handle shock loads at motor start or direction changes. The arm-spinner wheel is a sandwich made from 5 Home Depot bucket lids, you can't see the spring on that cable, it lives in a curved slot on the back side of the wheel, but you can see the spring in the return cable, after the arm comes up its just above the spinner wheel.
The cables are wound on two spools which spin on a common shaft, but the windings go in different directions. If the two spools were locked to the shaft, then turning the shaft would wind up one spool and unwind the other spool the same number of turns. But the two spools can not be fixed permanently together because the diameters of the wound cable are changing, one is winding when one is unwinding. So in between the two inner sheaves of the spools, I put a "clutch disc", just a circle cut out of a sheet of Scotchbrite pad. The two spools would try to move away from each other, I tensioned them up against each other with a couple of drawer slide brackets. The slide brackets mounted to the base which holds the spools, the little wheels on the slide brackets push on the inner sheaves, there is a screw adjuster which squeezes the Scotchbrite to an appropriate amount of friction.
Two spool drive designs evolved. The first one allowed the shaft to slide back and forth, the shaft had two pins, when it was all the way in one direction the pin on that end would engage the nub on the outer sheave of that spool, as described above this would drive that spool and the other spool gets dragged along by the Scotchbrite. The ability to play with one spool was handy during assembly and debug, you could move the shaft to a point where neither pin engaged, lock one spool with Vise-grips, and then a human could pull a cable, or wind up a cable, as needed without bothering the other spool. Hopefully this photo is not too big...
After it was all working, the second design just moved the spool drive pins inward, allowing almost a full rotation of a spool before the pin bumped into the nub. So that means there was almost one turn of differential motion available during the up/down travel. If you use larger diameter spools, the windup differential is less of an issue.
Unread 16-03-2011, 01:11
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Obviously you just use a winch, with the wires being the cables that go to the arm.
Wires bundling up is always an annoying issue. We didn't have that problem with our arm, but for our operator console, we bought a USB hub that has a retractable cable (then I tightened it, of course.)
