Go to Post A year where the students learn a lot and win nothing is more rewarding than a year where the team does well and doesn't learn much. - Molten [more]
Unread 01-03-2011, 01:42
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Minibot falls slowly?
http://www.youtube.com/watch?v=N96VeZedEec
A video is worth a thousand pictures, thus worth a million words
class team2412(GP):
    def __init__(self):
        GP.__init__(self)
        self.coopertition = True
        self.info = {"name": "Robototes", "school": "Sammamish High School, Bellevue, WA"}
        assert self.kind_people == True
Unread 01-03-2011, 04:00
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
Re: Minibot falls slowly?
you short the motors
Unread 02-03-2011, 17:41
2829ron 2829ron is offline
FRC #2829
2829ron will become famous soon enough2829ron will become famous soon enough
Care to expound? Would be appreciated.
Thanx,
David
Unread 02-03-2011, 17:55
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Maybe you could put some sort of ratcheting mechanism in there. http://www.vexrobotics.com/276-1546.html might be a good option.
-vivek
"we don't build robots, we build people"
Unread 02-03-2011, 18:02
FRC #2829
-vivek
Thought of something like that. Didn't want to stop it hard enought to make the bot fall off the pole though (kinda would defeat the purpose ).
David
Unread 02-03-2011, 18:32
bcootner bcootner is offline
FRC #1751
bcootner is an unknown quantity at this point
http://www.youtube.com/watch?v=a6EKw0RInRw
Our team's minibot does a very similar thing on purpose at about 1:48 in the video above.
Unread 02-03-2011, 18:38
FRC #2829
Ours is built differently, but could you explain how you got the motors to slowly roll? Ours prefers to zoom down.
Thanx,
David
Unread 02-03-2011, 18:42
liam.larkin's Avatar
liam.larkin liam.larkin is offline
We will find a way or make one!!
FRC #0272 (Cyber Crusaders)
liam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to behold
Ours also always comes down. Shorted the motors in series off the "normally open" on the limit switch.
http://www.frc272.com/2011Season/Min..._timed_run.wmv
I like this one the best. Hicups a little in the beginning before grabing. If 4.48 is a slow run for us I will take it.
David what is your gear ratio?????
Unread 03-03-2011, 14:50
FRC #2829
Am I supposed to know my gear ratio ? To be honest, I actually don't know all of that. I just built it . It uses the largest tetrix gears in the FTC mini kit, and they go to the smallest gears mounted on the wheels.
Thanx,
David
Unread 03-03-2011, 17:18
Thanx,
David
Okay based on that.....I am assuming you are using either a limit switch or household light swtich to start/stop your minibot when it hits the top. Take whatever side you have left either normally open/normally closed output (depends on your design) and short that across your motors in series and you will get something similar to our result
