Go to Post I looked at it and originally thought it was a crazy idea... then I looked at it again and it still sounds like a crazy idea. But crazy ideas tend to produce some excellent results. - Yipyapper [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 03-03-2011, 05:57 PM
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
Re: Anyone successful with camera in RobotPy?
Originally Posted by taichichuan View Post
Is this by any chance on a 64-bit machine? I've seen these errors (context-sensitive help file that is) on machines where the WRS workbench didn't install properly. You might try to reinstall Workbench to see if it solves the missing file problem.
As for the camera problem, try a lower resolution like 320x240 and loose the camera compression options. These might be stressing the stack space for the thread and causing the failure. 640x480 is really too big to be shipping across the net anyway at run time.
HTH,
Mike
ok, I reinstalled windriver and changed the camera feed size to 320x240, but I got the same problem, but this time when I pressed attach debugger another page popped up in windriver called FRC_paramtask with a list of deadbxx: in which xx varies whether a number or letter and after each deadbaxx: it said "Read access not allowed"
