Go to Post It only takes micro-seconds to release the magic smoke and empty the teams' budget. - Jim E [more]
Unread 03-03-2011, 17:33
tutkows1's Avatar
tutkows1 tutkows1 is offline
FRC #2077
tutkows1 is an unknown quantity at this point
Arcsin?
How do you calculate arcsin? edit: In Java?
I've seen that their should be a Math.asin, but netbeans doesn't recognize it.
Unread 03-03-2011, 18:31
Re: Arcsin?
Just curious, what are you calculating that requires arcsine ?
Unread 03-03-2011, 21:52
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Arcsin?
Looks like com.sun.squawk.util.MathUtils has what you're looking for:
http://www.wbrobotics.com/javadoc/co...MathUtils.html
--Ryan
FRC 766, 2015-, Mentor
Unread 03-03-2011, 21:53
Anupam Goli's Avatar
Anupam Goli Anupam Goli is online now
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Re: Arcsin?
The FRC Java library does not contain an arcsine method. The math class in the FRC Java library is a very stripped down version of the actual Java.Math class.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 03-03-2011, 21:56
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Arcsin?
Asin can be found as MathUtils.asin.
http://www.sunspotworld.com/docs/Ora...MathUtils.html
Eric Haskins KC9JVH
Unread 03-03-2011, 22:12
AKA: noops
Re: Arcsin?
Yea, he's right. Ignore what i said earlier, it should be in the MathUtils class. Click the logo in netbeans and find the class in the api documentation. Remember, all of those methods are static so you have to refer to them as MathUtils.asin(double a);
Unread 05-03-2011, 16:04
Re: Arcsin?
Or you could roll your own. Accurate to less than 3 minutes of arc.
#include <math.h>
double asin (double x) {
const double pi2=1.57079632679;
const double hroot2=0.707106781186;
double f(double x);
if (x<-hroot2) return -pi2+f(sqrt(1-x*x));
else if (x<0) return -f(-x);
else if (x<hroot2) return f(x);
else return pi2-f(sqrt(1-x*x));
double f(double x) {
return -0.000786215+x*(1.021878945+x*(-0.118183378+x*(0.344819444)));
void main (void) {
int i;
for (i=-100;i<=100;i++) printf("%f,%f\n",0.01*i,asin(0.01*i));
