Go to Post I'm sure I'm not the only one that feels like a blind man in a room full of sharp objects when it comes to programing. - Protronie [more]
Go Back   Chief Delphi > Technical > CAD > Pro ENGINEER / Creo
Unread 03-03-2011, 19:24
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
File Type?
With our minibot we wanted to put it on a cnc machine. we have it all put together in pro enginering. what file type do we save it as to use it on a cnc machine?
Unread 04-03-2011, 01:41
dtengineering's Avatar
AKA: Jason Brett
Re: File Type?
You should probably talk to the person responsible for the operation of the CNC machine.
Typically our team's process would be to export a 2-D drawing from Inventor of the surface we wanted to machine in to a .dxf format, and load that file in to MasterCam, where we would generate the toolpath. Once we had proofed the toolpath in MasterCam, we would generate the .nc file (the g code that would run our CNC router) and transfer that file to the computer that ran the CNC machine.
But you need to make sure that you have the correct post processor for your machine, and have selected the correct tooling, feed rates, and tool speeds for your material and machine.
You also need to plan for how you are going to hold your material in place while your are cutting it, so you'd best talk to someone with hands on experience using the machine that is going to do the cutting.
Jason
Unread 04-03-2011, 01:43
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Re: File Type?
You can also take your files direct from Pro/E into MasterCAM as 3d data, either in Pro/E native or .stp/.step. This is how our team gets the data to our CNC.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 04-03-2011, 08:07
skotmorris's Avatar
skotmorris skotmorris is offline
Windchill Product Manager
FRC #4909 (Bionics - Billerica Memorial High School)
skotmorris is an unknown quantity at this point
Re: File Type?
Awesome, great to hear you were able to model your minibot in Creo Elements/Pro. Please consider sharing it with PTC when it's complete so we can showcase it with other FIRST team's robots.
You should find out what software will be used to create the CNC machining program with. Most CNC programming applications can read native Creo Elements/Pro files, or you can create a standard export format like STEP using the Save A Copy command.
You can also create an NC model in your Student Edition of Creo Elements/Pro. You can setup the machining environment, create the required machining operations and export an NCL file which can be converted for use on any machine using a Post Processor.
Unread 27-01-2012, 10:36
team1512's Avatar
team1512 team1512 is offline
FRC #1512
team1512 is an unknown quantity at this point
Re: File Type?
We are struggling to open up the .stp.15 adn .asm.15 files in Pro. Any advice?
Unread 27-01-2012, 11:55
skotmorris's Avatar
Re: File Type?
Can you give me the full name of the files you are attempting to open and when you got them from? It is not clear from your question, exactly which file you are opening.
-Scott
Unread 20-03-2012, 21:00
arose839 arose839 is offline
Drive Train Boss
AKA: Amanda Rose
FRC #0839 (Rosie Robotics)
Team Role: CAD
arose839 is an unknown quantity at this point
Re: File Type?
In my experience, if we wanted to use the CNC, we used .igs files. We used .igs files this year to make side plates for our drive train.
