Go to Post To offer an opinion is fine, to demand that others adhere to your opinion is laughable. - JVN [more]
Unread 04-03-2011, 17:24
Dakota Dakota is offline
FRC #2805
Dakota is an unknown quantity at this point
Where do we get NXT-G?
I've read we have to use NXT-G to program the minibot, but where do we get that? The Lego site has been absolutely useless. Will NXT-G include the NXT "blocks" for the hitechnic controller?
Wolfpack Team #2805
Unread 04-03-2011, 18:07
KevinReid's Avatar
KevinReid KevinReid is offline
FRC #2609 (Beaver worX)
KevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to behold
Re: Where do we get NXT-G?
NXT-G is the programming software for the NXT Bricks.
It is bought from LEGO.
Unread 04-03-2011, 19:30
treffk's Avatar
treffk treffk is offline
botgirl
AKA: Kelli
FRC #1802 (Stealth)
treffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud of
If you buy an NXT brick by itself you have to purchase the license for NXT-G. If you buy a full kit from LEGO education or Toys'R'Us the software will be included.
BUT NXT-G will not program HiTechnic items, HiTechnic needs RobotC software or as I just found out LabView will work too. (http://usfirst.org/roboticsprograms/...t.aspx?id=6650) which you can purchase the license from http://www.legoeducation.us/store/de...ID=1355&bhcp=1. NXT-G is traditionally used in FLL (or home kits) with the LEGO sensors. RobotC is FTC's software and works with Tetrix items. It can be a bit confusing trying to find this information on the lego education website.
PM me if you have other questions about the brick or software, I work heavily with FLL and have assistant coached 3 different FLL teams.
"If you always says yes, what are your yeses worth?"
Alumna of FRC Team 1802
Last edited by treffk : 04-03-2011 at 19:59. Reason: realized a mistake in my answer... again
Unread 04-03-2011, 19:42
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
You are not required to use any programming on your minibot.
Unread 04-03-2011, 19:52
treffk's Avatar
botgirl
AKA: Kelli
FRC #1802 (Stealth)
But if you are using the HiTechnic servo controller or touch sensor(for example) you have to use the NXT brick which requires programing.
Unread 04-03-2011, 20:00
AKA: Matt B
FRC #1771 (1771)
Ah yes, I suppose that is true...
Unread 05-03-2011, 00:33
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
http://zone.ni.com/devzone/cda/tut/p/id/4435
Labview extension that makes you able to program NXTs. It works like a charm.
1000x better than NXT-G or Robolab or any of that beginner stuff. Be careful because you can't use all the labview functions on the NXT (Like the in range and coerce function is out).
There's a similar toolkit that lets you do robolab (since robolab is based off of labview).
