Go to Post I'd rather have a bot in front of me than a frontal lobotomy. - Neal Probert [more]
Unread 04-03-2011, 17:58
Mike o.'s Avatar
Mike o. Mike o. is offline
AKA: Mike O'Brien
FRC #1086 (Blue Cheese)
Mike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud of
Send a message via AIM to Mike o. Send a message via Yahoo to Mike o.
Re: Alamo Regional: Red cards
In the affected matches, are one or more robots not on the field? If so, it's probably a result of my #1 least favorite rule, where if you haven't passed inspection, and you participate in a match, your partners and you get red cards. Under another rule, if you don't participate, you get a red card. (That one I can understand.)
To elaborate a little more, I have added more to the two situations that EricH has mentioned:
  1. Eligibility: <T03> A TEAM will only be allowed to participate in a MATCH and receive qualification, ranking, and Coopertition points only if it has passed inspection. If it is learned after the start of the MATCH that a TEAM did not pass inspection, the TEAM’s entire ALLIANCE will receive a RED CARD for that MATCH.
  2. Match Point Exceptions: A TEAM is declared a no-show if no member of the TEAM is in the ALLIANCE STATION at the start of the MATCH; a no-show TEAM will be disqualified from that MATCH.
The way that they disqualify a team at the start of the match is through issuing a Red Card before the match starts.
Also, to clarify a point stated earlier. If a TEAM does show, but is without a robot, there is a button to BYPASS the TEAM, they should not be receiving a Red Card, since they had a member of the TEAM show for the match and should still receive all ranking, qualification, and Coopertition points.
Hope this helps a little with some of the confusion and sorry if it might seem a little repetitive.
Mike O'Brien
Founder, Almuni, & Mentor Team 1086
2010 GAL Division Finalist & Coopertition Award; NC Regional Winner & Quality Award; VA Regional Winner & Engineering Inspiration Award Winner
2009 CMP Team Spirit Award; VA Regional Winner & Chairman's Award
2008 VA Regional Winner & Chairman's Award
2007 & 2006 VA Delphi "Driving Tomorrow's Technology" Award
2005 VA Team Spirit Award; 2004 VA Imagery Award; 2003 Rookie Year
