Go to Post When twenty people tell you your hair is on fire, you don't need to look into a mirror to find out they're right. - IndySam [more]
Unread 04-03-2011, 20:20
jacob9706 jacob9706 is offline
AKA: Jacob Ebey
FRC #3574 (High Tekerz)
jacob9706 is on a distinguished road
Need Help with analog readings
i MUST have the dashboard read to another decimal point for analog inputs. 2 or 3 decimal places would be even better.
thanks in advance from,
jacob9706 and team 3574
Unread 05-03-2011, 01:29
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Need Help with analog readings
http://www.chiefdelphi.com/forums/sh...ad.php?t=93217
is asking the exact same question you are.
You need to make a dashboard project, open up dashboard main, right click on the indicator you want to change, go to display format, then play with the number of digits. Then build the project (same way you do robot code) and put it in c:\program files\FRC Dashboard
