Go to Post I can't help looking at the new center piece my wife put on the dinning room table and think to myself, "non-functional decoration" - DarrinMunter [more]
Unread 04-03-2011, 17:44
Jogo Jogo is offline
FRC #0353 (Pobots)
Jogo is on a distinguished road
Operator Console
To week 1 teams (or anyone with previous experience): has anyone successfully received data from switches connected to the operator console to select autonomous routines? I just want to ensure that the packets are sent and that we don't run into trouble on practice day with this.
Thanks!
Unread 04-03-2011, 18:08
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: Operator Console
we have our autonomous selector switches on our robot. we read the switches at the beginning of autonomous and select a mode from there. If you don't have success with switches on the operator console, you can always to this and put them on the robot.
Unread 04-03-2011, 18:16
FRC #0353 (Pobots)
Yeah we've typically done the robot switch because we thought it was the only way, but I noticed in the basic LabVIEW framework that they read data from the operator console in the autonomous independent VI. I want to see if teams have used this successfully.
Unread 04-03-2011, 20:38
Sean1038 Sean1038 is offline
FRC #1038
Sean1038 is an unknown quantity at this point
Yes, we have successfully received data from our switches on the I/O Module and have used the switches to select auton routines. We just used the Enhanced IO vi in LabView to use the data.
Unread 04-03-2011, 23:30
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Last year we did this. We just went into the I/O panel of the DS and and set them in there, rather than hook up the board.
Unread 05-03-2011, 00:13
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
We did it with the joystick throttles last year, and this year we're putting on a few switches and potentiometers to choose the mode.
Just read the switches and stuff during disabled. It's probably a good idea to display the information to the dashboard also.
Unread 05-03-2011, 09:20
FRC #0353 (Pobots)
Cool, thanks everyone. Out of curiosity, why does it have to be in disabled, rather than autonomous independent? Also, what is the Enhanced IO vi?
Unread 05-03-2011, 11:30
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Don't quote me on this, but I believe in disabled mode, the robot still receives live data from the driver station, but can't act on it, and when it transitions in to autonomous, the data from the driver station is 'latched' which means the last values sent when the transition occurred will be re-sent over and over regardless of any changes you make. Theoretically you could set the switches in disabled mode, and have the robot read them in autonomous, as long as they were in the correct position at the transition point. I haven't tested this yet, it was explained that way to me by another mentor, so take it with $0.02 of salt.
Matt
Matt Krass
Unread 06-03-2011, 09:32
But since it is accurate, I'll quote it anyway. The only thing I'll add is that this is true of joystick settings and DS I/O. Anything on the DS that could be used to influence or drive the robot during auto is latched. If you don't need to have your hands on it to keep the value, you can manually set the value during disabled and the robot can read it during auto.
The DS compatible I/O can be virtual -- set on the screen -- or via the Cypress board. The enhanced I/O is far more flexible, but is not virtual. You must use the board with enhanced I/O.
Greg McKaskle
