Code Review!!
So now that building (for us) is officially over, I'd like to do a massive code Review. Now, unfortunately there are only two Java programmers on our team (actually two programmers in general), and so I'd like someone who is outside of the two of us to check the code out, see if we did anything fatal. Of course, only we can check our math, but i'm looking to see if i made any stupid mistakes or if i need to improve an algorithm a little bit. Here is the URL to our google code project:
http://code.google.com/p/2011deployable-1002/ Leave comments and Enjoy! P.s. I think there should be an entire subsection of a forum dedicated to this type of thing. It would be quite useful. |
Re: Code Review!!
Minor nit: The URL to checkout on http://code.google.com/p/2011deploya...ource/checkout has a space in it so you can't copy/paste it.
Things that jump out as possible problems:
Also one Java coding conventions. I wouldn't change it at this point, but you asked for a code review so you are getting one from a real Java programmer .
And some things I particularly liked:
Good luck! |
Re: Code Review!!
Well, based on our drive format of choice currently (currently we are doing tank, and if you noticed we had a software switch to go from meccanum to Tank). The robot would not be able to move really well anyway, and wouldn't the Jags that were declared up until the exception was thrown be running?
2. I'm sure that there should be while(isEnabled()) instead of a while(true), while loops with boolean true are normally used for software written for running on actual computers, no embedded systems. I'll change that so I don't do something fatal. 3. We were planning on using something we call "minithreading" during autonomous; basically, we have the compressor run as a background process (it will only check the switch once every 30 seconds orso) and have the arm and drive being constantly processed. 4. I understand about CPU Starvation, but we shuld get good results for teleop in this setup. In autonomous, things are going to be different if we implement actual threading. (two possiblities: implement threading or have everything written as a step function to increment constantly). I normally stick to Java convention, this time around i forgot for a few seconds. (Also, I hate having instance fields at the bottom of the class) Thanks for your review and help. I will amend all of what needs to be amended now. |
Re: Code Review!!
Re: Code Review!!
The pressure switch on the compressor.
Re: Code Review!!
We considered using a threading system. The extension of Runnable is just a remnant of it. We ultimately removed it due to the time management problems we might have met. We might revive it if we found a way to implement it.
#7
Re: Code Review!!
How much pressure can build up if the compressor runs uninterrupted for 30 seconds.
#8
Re: Code Review!!
More than what is legal. We're going to change that.
#9
Re: Code Review!!
> thrown be running? Yes. Although I suspect the main code would reference one and through a null pointer stopping the whole program after that. As you noted, this is a point of mainly obscure interest because moving would be so poor anyway. > but we shuld get good results for teleop in this setup Right. Because there isn't threading. |
#10
Re: Code Review!!
When using CAN, threading will improve your bus utilization by approximately 3x if using the Black Jag Bridge. Potentially more if using the 2CAN. The reason is there is more bus bandwidth than that consumed talking to a single Jag. That means that you can have messages in flight to up to about 3 jags at a time, thus reducing the overall time needed to update all of your CAN Jags. Only by using multiple threads can you actually send more than one message at a time.
Remember that you can only ever have one message TO THE SAME JAG at a time. All parallel messages must be to different Jags. If you send more than one message to the same Jag at the same time, the messages will simply be serialized by the library (i.e. things will still work, you just won't see a performance improvement). -Joe |
