Go to Post Learning from the innovations of others is part of what makes FRC great, regardless of your own teams accomplishments or lack thereof. - hg273 [more]
Go Back   Chief Delphi > Competition > Regional Competitions
  #31   Spotlight this post!
Unread 05-03-2011, 20:23
Onward through the fog.
Re: Lessons learned for Week 2 Regionals?
There just may be a reason for forehead protectors this year. After watching Blair get bopped by a tube, that was the first thing that popped into my head.
Jane
~ Helen Keller
(1880-1968)
  #32   Spotlight this post!
Unread 05-03-2011, 20:32
pfreivald's Avatar
AKA: Patrick Freivald
Originally Posted by thefro526 View Post
Minibots are more important than tubes.
I disagree, vehemently. At FLR, this simply was not true.
If you don't have a minibot, go make one. If you don't have a deployment system, go make one of those too. Seriously.
...and this I agree with 100%.
Even though the game is called "Logomotion" in most Qualification matches I played in and saw, Tubes could not, and did not offset the points scored by a single minibot.
While this was mostly true, if one wants to be a truly competitive, top-tier team, it simply wasn't the case. FLR had many matches that were 60+ points to not very many points, with most of those points coming from tube scoring.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #33   Spotlight this post!
Unread 05-03-2011, 20:34
Chris is me's Avatar
AKA: Pinecone
And how many teams did you see an alliance win the minibot race and lose the match?
  #34   Spotlight this post!
Unread 05-03-2011, 20:37
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
I understand that devaluing the minibot would hurt some teams that focused on that, but what about the teams that focused on putting up tubes? You're telling me that all of the work that my team has done to score 5 game pieces should be erased by one robot that didn't score any tubes and put up a minibot? Something's not right there.
So a lack of, or incorrect, analysis of the game requires a change in the game to make it more advantageous to your lack of, or incorrect, analysis of the game? Interesting request.
  #35   Spotlight this post!
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
It seems that minibots are like ramps were early in '07. It was extremely hard to win a match against a double ramp if you had no ramps. But, once both alliances had ramps, matchs were decided by tubes. As more and more teams get consistent minibots, tube scoring will become more important.
  #36   Spotlight this post!
Unread 05-03-2011, 20:41
AKA: Pinecone
If it was a 30 point bonus for minibots, I would agree. But the "race" nature inserts so much entropy into the match results that the winner of the match is rarely decided on by factors you could have actually designed for.
  #37   Spotlight this post!
Unread 05-03-2011, 20:42
LH Machinist LH Machinist is offline
LH Machinist has a spectacular aura aboutLH Machinist has a spectacular aura aboutLH Machinist has a spectacular aura about
Line tape problems
I saw a team identify tape problems before a qualification match, it looked scuffed or dirty from the stands. The field crew made a quick repair that the team appeared not to like and had to leave the field under protest. During autonomous their robot deployed the uber tube way prematurely.
Was the team correct or was it a field issue. I tend to believe the team because after the match, the field crew carefully repaired the tape.
  #38   Spotlight this post!
Unread 05-03-2011, 20:43
pfreivald's Avatar
Us. Over and over again.
We were the most consistent minibot at the regional, with claw gremlins that kept us out of the tube-scoring quite a bit. We lost most of our games in spite of winning every minibot race we entered.
(...and I will maintain to my dying day that our last semifinal match, we did not deploy our minibot early... It wouldn't have made a difference (beyond pride) anyway, but dang it, the refs got that call dead wrong! Video will vindicate us, I do declare! )
I saw quite a few matches where the alliance that won the minibot race also won the match, but by a greater margin than the minibot points... There weren't that many where a successful minibot actually made a win/loss difference (though some of them were critical, of course).
Team 1551
I write books, too!
  #39   Spotlight this post!
Unread 05-03-2011, 20:47
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Make sure your minibot stays on your hostbot. I'll say it again: if you care about getting the minibot bonus, and if you value the work you put into building it, then make good and sure it doesn't fall off and get run over by a hostbot. It feels like watching your pet turtle try to cross the freeway.
Originally Posted by Jeffy View Post
5/6 #1 seeds won the regional.
1/6 #2 seeds won the regional.
It appears the ranking system is doing its job.
A minor correction - the winning alliance in NH was 175/1519/176, which was the third seeded alliance.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
  #40   Spotlight this post!
Unread 05-03-2011, 21:25
commodoredl commodoredl is online now
AKA: Dan Lavoie
FRC #2877 (LigerBots)
commodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud of
Did any of the other regionals have issues with their fields detecting minibots? At FLR, almost every minibot to reach the top was undetected by the touch sensor. We had to have referees keep track of which minibots were scoring, and that wasn't good when things got close at some points.
Technical Mentor
Team 2877 - Ligerbots
2016-
Previously:
Team 578 - Red Raider Robotics
2007-2014
  #41   Spotlight this post!
Unread 05-03-2011, 21:57
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Based on webcasts I watched, I think all Regionals had issues with minibot detection issues. All had refs holding up fingers and jumping/throwing arms up to indicate when hit.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
  #42   Spotlight this post!
Unread 05-03-2011, 22:05
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
Well everyone has said it a million times but minibots are extremely important. Ours carried us to the finals but our manipulation wasn't key.
Make sure that your manipulation can pick up tubes without any error from the floor. Aside from that, figure out how to have a fast minibot. We are actually trying to make ours faster which is almost impossible
Tubes + Minibot = Elim Wins and Champions
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
  #43   Spotlight this post!
Unread 05-03-2011, 22:09
smistthegreat's Avatar
smistthegreat smistthegreat is offline
robots is a hard job
AKA: Brian Smist
FRC #4930 (The Electric Mayhem)
smistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond repute
Just an observation from going to FLR today: I was very surprised by the amount of teams throwing tubes. I'm not sure how I feel about it, but for some of the matches, especially with powerhouses 217 and 2056, it seemed like the human players throwing tubes were doing nothing but feeding their opponents. If you throw a tube into the middle, you're basically giving it to the team with the best manipulator.
University at Buffalo | Mechanical Engineering | Class of 2016
2014-20?? | Mentor | 4930 | The Electric Mayhem
2013 | Mentor | 229 | Division by Zero
2013 | Mentor | 4124 | Integration by Parts
2009-2012 | Student | 1507 | Warlocks
  #44   Spotlight this post!
Unread 05-03-2011, 22:10
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
You must have a working mini bot to win.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
  #45   Spotlight this post!
Unread 05-03-2011, 22:25
BGiraud's Avatar
BGiraud BGiraud is offline
AKA: G
FRC #1676 (Pascack Pi-oneers)
BGiraud is a splendid one to beholdBGiraud is a splendid one to beholdBGiraud is a splendid one to beholdBGiraud is a splendid one to beholdBGiraud is a splendid one to beholdBGiraud is a splendid one to beholdBGiraud is a splendid one to beholdBGiraud is a splendid one to behold
One extra is a must. They do break.
