Go to Post This thread is a reminder to myself that I have 29 more days to sleep. :) - Seth Mallory [more]
Unread 02-03-2011, 15:33
benjaminDVBD's Avatar
benjaminDVBD benjaminDVBD is offline
FRC #3316
benjaminDVBD is an unknown quantity at this point
PWM problems
Our jaguar isn't getting output from the sidecard.
we have 4, 2 using PWM and 2 using CAN.
the 2 CAN are working fine (even though they have no code. the light is switched on and isn't blinking)
the other 2 PWM jaguars aren't working. they have code, and yet their light is blinking non stop and are not working (even in the slightest).
we have no idea why this is happening.
we checked the code (including past versions) and it isn;t working.
we checked the cables with the FLUKE and there seems to be no problem.
any ideas (please?)
Unread 02-03-2011, 15:53
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: PWM problems
Did you update the firmware on the jaguars? That may be one reason.
Unread 02-03-2011, 16:52
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: PWM problems
yes. if you updated the FW on the pwm ones, they will not as they must get a heartbeat signal from the crio over CAN.
if thats the issue, you might have to run all you jags on CAN... not very hard to fix in code and pretty easy to accomplish if you already have CAN elsewhere...
Unread 05-03-2011, 23:52
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Re: PWM problems
That's not correct. Jaguars with updated firmware will still operate with PWM.
I would check to make sure the PWM cables are plugged into the Jaguar and the digital sidecar in the correct orientation.
-David
Unread 05-03-2011, 23:56
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
Re: PWM problems
We have had the PWM outputs on the side car be bad, with the 2009 robot.
Try a different output location.
The programmers should be able to change that easily.
Unread 06-03-2011, 00:54
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Re: PWM problems
Do you also have issues with cRIO connectivity?
2604 had a similar problem to what you are describing. Our drive system is/was 4 wheel CAN mech drive. Then our 'arm' is powered via 4 pwm jags.
The issue we repeatedly had was
"Unable to allocate PWM channel" (as seen in the driver station error window/output text box)
If you have both of these issues what you may want to look at if your labview install, our happened to be corrupted thus our 'compiled' code wasn't actually doing what we programmed it to do. This being the problem all older revisions proved unworkable. (It maybe possible with C++ or Java, I don't know)
Is now an engineer thanks to FIRST.
Last edited by XXShadowXX : 06-03-2011 at 00:58. Reason: Included more information about the experience.
