Go to Post FIRST robots are not six week projects. They are never ending projects where the requirements are changed on an annual basis. - ChrisH [more]
Unread 05-03-2011, 15:38
Nicandy's Avatar
Nicandy Nicandy is offline
AKA: Nicole/Andy
FRC #3580 (Marinerds)
Nicandy is an unknown quantity at this point
Unhappy Tank Drive Troubles
Okay, so We have the arm motors programmed pretty as you please, we are using a tank drive to control the two drive motors, as well as the two arm motors that we have. The arm motors do exactly what they are supposed to do. as well as our drive motors, but we are having issues with programming the drive motors to turn or re-invert themselves to turn. is there anyone out there who can give us some insight? we are completely stuck and out of ideas on this. There is also a photo that might help you guys. thanks very much from the Marinerds.
Unread 05-03-2011, 19:10
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Tank Drive Troubles
I don't know labview at all, but do you need to invert one of the joystick axis?
Remember that full forward is -1.
Unread 05-03-2011, 19:20
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Easy way to test for proper operation of a Tank drive.
1.Put the robot up on blocks so the wheels are off the ground and not touching anything.
2. Push whichever joystick corresponds to the left side forward. Check if the left side drive wheels move forward.
2a. If they don't go to Begin.VI and wire a true constatnt into the Invert Left terminal of the Open X Motor drive.
3. Push the right joystick forward. Check if the right side drive wheels move forward.
3a. If they don't go to Begin.VI and wire a true into the Invert Right terminal of the Open X Motor drive.
4. Save and rerun, or rebuild and set as startup
5. Verify both sides now move in the proper direction.
Unread 06-03-2011, 11:00
Nicandy's Avatar
AKA: Nicole/Andy
We want one joystick to control forward and backward, as well as turning left and turning right, while the other joystick will control the arms elevation.
and our problem is that we can't figure out how to program the first joystick to do all four things. we can only get it to do either forward and backward, or left and right.
Unread 06-03-2011, 11:05
Originally Posted by Nicandy View Post
We want one joystick to control forward and backward, as well as turning left and turning right...
Here's your problem: What you are describing is called Arcade Drive, not Tank Drive.
Your FRC LabVIEW installation supports Arcade Drive.
See attached screenshots of the Functions Palette and the Help.
Name:	Arcade Drive.png
ID:	10342  Click image for larger version
Name:	Arcade Drive Help.png
Unread 06-03-2011, 13:48
Nicandy's Avatar
AKA: Nicole/Andy
well then can i use two arcade drives? or one tank and one arcade drive?
because i need the one joystick to be able to control the arm, and one to control the driving.
Unread 06-03-2011, 14:07
You could, but that's not the way it was intended to be used.
Use the Arcade Drive VI to control the driving.
Don't use Arcade or Tank Vis to control non-drivetrain motors. See this post.
Unread 06-03-2011, 14:33
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
The arcade drive VI takes one joystick input, IIRC. Maybe an X and a Y input. Either way, they come from the same joystick.
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 06-03-2011, 15:20
Arcade Drive takes 2 joystick inputs.
That's the way it's usually done, but it's not required. The 2 inputs could come from 2 different joysticks.
Unread 07-03-2011, 13:28
Nicandy's Avatar
AKA: Nicole/Andy
Ether, thank you so much, you really helped answer a lot of questions.
Unread 07-03-2011, 16:23
You are welcome.
