Thread Tools |
Rating:
Display Modes |
Re: Possible FLR Hacking?
Matt |
As for the battery thing, I'm aware that it was likely the cause of the issue. I just mentioned it because the robot didn't seem to power down, though I now realize the bridge probably died on its own. And once again I mention that someone on our team mistakenly marked that battery as charged, and we didn't have time to check it before we queued. |
We were doing some testing with last year's robot today, and it's in pretty hurting shape. Even with a full battery, some very weird stuff can happen due to motors stalling. It is configured as a long-base 4WD tank drive with grippy wheels on front, slick wheels on back, and riding on carpet. Clearly, this configuration is really bad at turning.
Example of weirdness: When we move the joystick full left or right, the robot sometimes shoots forward or backwards. We eventually figured that this was because one of the motors would trip its fuse while trying to turn, and the other one would then power the robot full-speed forward or backwards, depending on your direction of turn. So it ends looks like something un-commanded is happening, when in fact it's an interaction of the underpowered battery, fuses, and environment. |
Everyone knows that every event does not get finished without a couple unsolved issues. One of those issues at the FLR was the few events were some robots seemed to be doing things on their own. I have seen similar things at other events every year. Is this worthy of being called hacked? No. Do I think my student jumped to a rash decision and posted this thread before he thought of what it is implying? YES Hopefully he has thaught of what he did so when we talk about it he will have learned a lesson and this will all be over.
FLR, was a great event. Thanks to everyone that put in a lot of long hours to make it a success. This was the first regional that the students on my team have attending and they had a great time. Lets give congrats to the winners, praise the great job that every team did and learn from our mistakes and get ready for the next week. |
#8
I realize that this was likely not hacking but it was still a possibility. I was trying to gather opinions with this thread, nothing more. FLR is still the best event I've attended outside of the Championship thus far, and I have nothing against any of the teams or volunteers that were there. Sorry if it came off otherwise.
#9
The original post was coherent and well-written. The discussion since has been calm, thoughtful and informative. The topic is one that is always present and does not need to be kept locked away in the attic. You are reacting very strongly to something, but I'm not sure what that something is. However, using only what is written in this dicussion thread as a guide, I see nothing troubling. Blake |
#10
Unless you know the situation , then you don't know what is reacting strong or not. This has nothing to do with how it is written. |
#11
At the risk of being rude, it sounds as if you might be reacting a little strongly. Blake might not (and probably does not) know the situation, but I see no reason to respond snidely to someone who is simply offering their opinion. If there is perhaps, something more to the situation, then let it go at that.
#12
Edit: That being said, there are numerous reasons why robots would act erratically. My team had a match where our robot would turn right every time our driver let go of the controls, but this turned out to be a fault with our control system. I think the joysticks weren't zeroed correctly or something like that. Last edited by Norman J : 06-03-2011 at 20:11. Reason: Forgot something |
#13
I believe the burden of breaking WPA2 alone is great enough to prevent this from being an issue, ever.
#15
After that, I'm not so convinced the system is that safe, it's worth looking in to. I don't think this particular instance is evidence of that, but I think it highlighted the fact it may be a problem. So far everyone has said that there was no hacking incident based on several plausible, likely explanations for the events that occurred. Other than relying on WPA security I haven't seen much counterargument about the 'hacking' not being possible. Maybe I'm just paranoid, but that's my $0.020000000000000001 (Sorry, using an Intel...) |
