Go to Post you might want to consider the Edu-Robo-Whatevertheheckitscalled RC - Matt Krass [more]
Unread 06-03-2011, 12:44
Jash_J's Avatar
Jash_J Jash_J is offline
Lead Strategist
FRC #1241 (THEORY6)
Jash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud of
2010 Bridge Problem on 2011 bot
So on our practice robot, we are using last years bridge and router due to the fact that the new bridge is on the shipped robot. While we are practicing driving the driver station disconnects from the robot. We are confident that there is a problem with the bridge. We have tried putting the robot on blocks and it worked perfectly meaning that there is a problem with the shaking of the cables as the robot is moving. Does anyone know how to fix it?
Jash Javeri
FRC Team 1241 - Mentor/Alumnus
2013 World Champions! (1241, 1477, 610)
"Coming together is a beginning. Keeping together is progress. Working together is success." - Henry Ford
"I'm a great believer in luck, and I find the harder I work the more I have of it." - Thomas Jefferson
Unread 06-03-2011, 12:47
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: 2010 Bridge Problem on 2011 bot
Actually I'd suspect power first. How is the bridge powered? Is it in the proper 12V boosted radio power supply on the PD?
The reasoning behind my theory is that in the air on blocks the motors are under much less strain, and pull much less current. High current can cause voltage fluctuations that can screw things up. Verify the connection of your bridge power system.
Matt
Matt Krass
Unread 06-03-2011, 12:49
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Make sure the powerd cord for the bridge is strain relieved using a ziptie and try hot-gluing the barrel connector to the bridge.
Unread 06-03-2011, 13:01
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Check this post for instructions on how to install a service loop for the radio:
http://www.chiefdelphi.com/forums/sh...33&postcount=6
