Go to Post Magic Smoke. One whiff and you never forget. - JohnBoucher [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 06-03-2011, 13:06
Re: Field Issues
Interesting, but that sounds like a "it couldn't hurt" solution, rather than a required one.
At NJ most teams ran with 01.05.11.00.
The 2/27 version is identical, except in how it handles changes to IP settings, only noticeable on a small number of laptops, but maybe you had a lot of those if local teams all purchased the same third-party laptop on sale.
At NJ, we did upgrade a few driver stations with the newest edition.
Of course, since it couldn't hurt, upgrading to the 2/27 version is probably a good idea anyway.
Originally Posted by tr6scott View Post
At Kettering, even though 1.05.11 was supposed to be fine, it was found only 2.27.11 worked with field.
all classmates had to be flashed to 2.27.11, there was one flashdrive with the firmware in the building and no open wifi to the internet.
There was many factors to the 3-4 hour delay we experienced on Friday, this was one of them.
Robot inspection was passed on Thursday with 1.05.11 firmware, shown to not work on Friday.
Unread 06-03-2011, 13:27
TPNigl TPNigl is offline
FRC #0069 (Team HYPER)
TPNigl is an unknown quantity at this point
Re: Field Issues
Yea, I'm seconding the whole 02.27.11.00 thing. 01.05.11.00 was fine on practice day, but they had everyone move to 02.27.11.00 by the first day of comp.
Also, at least for java users, update netbeans so that it matches the new cRIO image. We had a very unofficial way of fixing ours w/o internet (our programming mentor used hacking skills). Try to fix it in a better way though if possible, haha
2011 Pit Crew:
2011 CT Xerox Creativity Award
HYPER Alumni
Unread 06-03-2011, 15:49
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
Re: Field Issues
Some additional detail based on my observations at Trenton (thanks Mark for the great list!)
Originally Posted by Mark McLeod View Post
Radios:
  • When setting the WPA, plug in Ethernet before power.
To expand on the situation behind this - the WPA configuration kiosk apparently has sporadic problems and will report a "failure to configure IP, wrong operating system" error (or something like that - can't remember the exact wording, sorry!). Usually the bridge will still be configured OK, but better safe than sorry. Hopefully the word can get out to the other regional volunteers so everyone knows the correct kiosk procedure is to plug in ethernet 1st, then power 2nd.
Driver Station:
  • Wrong rev. Must be this year. Either 01.05.11.00 or 02.27.11.00 are fine. Older ones mean your robot will never link to the field.
To expand on this, using DS Rev 01.05.11.00 but having multiple IP addresses configured on the network adapter will also mean your robot will never link to the field. I think this is what jhersh meant when he euphemistically explained that DS rev 02.27.11.00 would "ease proper configuration of the driver station laptop's IP configuration (making you more likely to successfully connect to the field)." Prior to rev 02.27.11.00, setting the team number in the DS config just set the additional IP for your team without getting rid of any additional pre-existing IP addresses that may have been configured.
Several teams at the Trenton regional found this out the hard way when they borrowed Classmates from spare parts - the spare parts classmates all had DS rev 01.05.11.00, and also had an existing IP of 10.0.0.5. - so any team using a spare parts Classmate could not connect to the field initially.
Again, better safe than sorry - probably best not to consider DS rev 02.27.11.00 "optional".
Huge thanks to all the Trenton volunteers but especially Mark, "NI Greg", "NI Ben", and "FTA Pete" for all the hard work!
- Ron
Team #2607 controls mentor
FIRST Mid-Atlantic Volunteer
FRC Team #2607 Mentor
Unread 06-03-2011, 16:20
Re: Field Issues
It can be an issue for teams who switch their IPs around a lot, or if you borrow a laptop from another team or Spare Parts.
That's why the vast majority of teams won't see this.
It'll only cause a problem the first time you go to use it.
If you connected at least once before by tether in the pits then you're good and it won't crop up later or anything.
The way to tell if this was happening to you is pretty simple.
The symptoms are: the Driver Station can't see the robot on tether.
If you check your IP settings use the Advanced button down at the bottom (1st attached image), and you'll get a list of the IPs associated with that network adaptor. Just delete the extras that shouldn't be there leaving you with one IP address as in the 2nd attached image.
Hey Ron,
Want to report on the CAN bus issues you debugged?
That's useful for teams to know, too.
ID:	10352  Click image for larger version
Unread 06-03-2011, 16:44
AKA: Ron R
Re: Field Issues
Hey Ron,
Hey! Yep, will probably take another day or two before the students and I finish pouring over all the runtime data we collected. Preliminarily it looked like stray CANBus exceptions would cause FRC_NetworkCommunication to block, and therefore cause FMS<->DS<->Robot comms issues whenever stray CANBus exceptions would occur - but now looking at all the data we're not sure if this is the case. I told Greg we'd write everything up and send to him and Joe for review.
Quick question on the DS tethering - the students say they were able to tether successfully with the borrowed Classmate and "multiple IP" situation before going on the field......they would have done that to charge the pneumatics since we have an off-board compressor this year. So I'm wondering if the multiple IP problem is a cRIO issue, or an FMS issue?
Anyway, safest procedure is just to check the IP settings!
- Ron
Unread 06-03-2011, 17:12
rcflyer620's Avatar
rcflyer620 rcflyer620 is offline
Advisor, BAA board member
AKA: Mark Eastman
FRC #2199 (Robo-lions)
rcflyer620 is an unknown quantity at this point
Smile Re: Field Issues
I watched Trenton all weekend and tracked who won on which side of the field. This is my third year as an FTAA at Chesapeake and it seems like evey year someone complains that one side of the field is favored. I can tell you this was not the case at Trenton. It was very nearly a 50/50 split. Hopefully that holds up at Chesapeake!
2013 Battle O' Baltimore Event Coordinator
Finance Officer - Baltimore Area Alliance
Unread 06-03-2011, 17:31
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Re: Field Issues
The account being named Driver and not being able to change the name to Driver, ton top of a lot of CAN issues caused us much trouble. We are setting up at least 4 computers for Hartford, and hopefully we'll be able to make practice matches to test them.
I did not know that was why the decorator didn't show up around the DS windows. Thats a really useful tidbit of information.
Unread 06-03-2011, 18:38
jcbc's Avatar
jcbc jcbc is offline
AKA: Julie
jcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the rough
Re: Field Issues
Ditto on the Windows account being named exactly Driver with the uppercase D in order to work with the FMS.
Unread 09-03-2011, 17:47
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: Field Issues
Don't know if it has been mentioned or changes somewhere in the great update loops of FIRST, but at Kettering the reflective tape used on the field did not match at all what was sent in the KOP sample.
The tape I had purchased and tested with, had reflective properties similar to sample tape provided in the KOP.
Using this tape the Line sensors, when placed approx. 2" above the floor, we had to detune the sensor all the way, and if the sensor got closer than 1.5" the sensors would false trigger.
At Kettering, we had to turn up the sensitivity almost 100%, and the sensors worked over the carpet, but when we had the bot in the pit, the sensors would false trip on whatever they used to cover the pit floor.
I was pretty nervous going into the first match, with no practice matches.
So be warned, if you have tuned your sensors to the KOP sample, you better make a trip to the practice field before your match.
Unread 09-03-2011, 17:53
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Field Issues
Scott,
While this is an excellent warning to any other teams that may have made this mistake, I do feel compelled to point out that this is not really a field issue. The reflective tape provided in the KOP was a sample of the material used for the reflective targets on the scoring grid. No sample of the grey gaffers tape used for the lines was provided in the KOP, but the manufacturer and product description were published by FIRST.
Unread 10-03-2011, 08:52
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
Re: Field Issues
True that...
Silly me to think that the KOP unidentified reflective sample of 2" material would be used with line tracking sensors.. Silly me to think that Pro-Graff tape was "generic" (akin to Duct tape) name as opposed to specific manufacture of tape.
The learning curve of a first year mentor.
While I am on this exposing my sins, although off topic here, can someone tell me why we get autocad for free and publish all the area drawings in .pdf forms?
I don't know how many times I had to scale a .pdf printout to set up the "Y" line on our school floor.
Live and learn.
Unread 10-03-2011, 09:03
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Field Issues
By no means was I suggesting that FIRST made it clear which tape was which or easy to understand, merely pointing out that the information was there.
You are not the first team I have heard with this confusion (there are many posts here on CD with/about it) and I'm fairly sure you won't be the last.
Regarding the field drawings, many of us have been wondering for the last few years why FIRST won't just publish the CAD in some standard format, ocassionally aloud to the GDC or other FIRST officials. With Autodesk, PTC and Solidworks all sponsoring FIRST, it seems like it would make a lot of sense to publish CAD in addition to the drawings.
Unread 10-03-2011, 14:33
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: Field Issues
This has long been one of my pet peaves with FIRST. I am a Tool Designer for a major aerospace company. Every drawing I produce contains the following General Note: "Analyze <your CAD system here> model for all non-critical dimensions and information not shown" I have never gotten a good explanation for why the models of the field are not released. It would surely help with finding those dimensions FIRST did not think were critical enough to add to the drawing. The alternative I have used for severl years is to get the .pdfs and build my own models based on the drawings.
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Unread 12-03-2011, 21:34
Warlord Warlord is offline
He-Who-Does-A-Little-Of-Everything
Team Role: Driver
Warlord is a jewel in the roughWarlord is a jewel in the roughWarlord is a jewel in the rough
Re: Field Issues
We were having extreme communication issues for basically all of Thursday and we couldn't figure out what it was. After a ton of other things we stopped printing things to the display and that seemed to fix some of our problems.
Unread 12-03-2011, 21:43
bobosalad's Avatar
bobosalad bobosalad is offline
FRC #2518 (Spartans of St. Jude)
Team Role: Driver
bobosalad is an unknown quantity at this point
Re: Field Issues
(Week two)
At Lake Superior regional it started with the laptops having to be updated to communicate. Then a minibot tower was knocked over, like literally leaning on the side of the field. The problems subsided after a tube hit the antennas to send info back to Manchester meaning we could not send score data to Manchester until it was fixed a few minutes later.
Spartans, Prepare for GLORY!
