Go to Post Looks like a perfect device for scaring the cats :D - Dan Petrovic [more]
Unread 06-03-2011, 15:24
ENIAC's Avatar
ENIAC ENIAC is offline
AKA: Matthew Petersen
FRC #5958 (Blue Wave Robotics)
ENIAC is a jewel in the roughENIAC is a jewel in the roughENIAC is a jewel in the roughENIAC is a jewel in the rough
Safety lights
Does anyone know what a solid light means, or if there is a manual for it somewhere?
Unread 06-03-2011, 15:57
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Safety lights
If you are referring to the robot status light, I would check to see if the jumper is installed properly as shown in this document
blink codes are here
http://decibel.ni.com/content/docs/DOC-3120
EDIT: oh, wait, for some reason I skimmed right past steady on in the list. Maybe there is nothing wrong after all (at least with the light).
Unread 06-03-2011, 16:09
ENIAC's Avatar
Re: Safety lights
Thank you. Our robot was acting up on bag and tag ( ) and one of the symptoms was a steady on with occasional flashes of off. It may have been a jumper, but it doesn't explain the rest of it.
Unread 06-03-2011, 16:29
Re: Safety lights
Fast Blink = not communicating
Slow Blink = disabled
Long on/short off blink = Teleop mode (what you described)
Solid on = Autonomous mode
Unread 06-03-2011, 19:17
Electrical Engineer
Rookie Year: 1995
Re: Safety lights
Mark,
Last year, they went to five codes as follows:
Solid ON = Autonomous Enabled
Solid ON, but blinks OFF every 1.5s = Teleoperated Enabled
Slow Blink (900ms on/ 900ms off) = System Disabled; caused by system watchdog, user watchdog or Driver's Station set to disabled
Fast-Slow Blink (200ms on/900ms off) = Low Battery (<12V) or no user code AND system disabled either by system watchdog, user watchdog, or Driver;s station set to disabled
Fast Blink (200ms on/200ms off) = System error: No driver's station communication, bad cRIO Image, bad team ID, extensive comm. error
I have seen no documentation this year so I assumed it was the same...
Do you have a link to current (2011) blink codes?
Regards,
Mike
Mike Betts
As easy as 355/113...
