Go to Post My goal as a mentor is to make myself irrelevant. Is that possible? Probably not. But this is one place I am willing to aim stupidly high. - Ian Curtis [more]
Unread 04-03-2011, 19:27
Teamcodeorange's Avatar
Teamcodeorange Teamcodeorange is offline
FRC #3476
Teamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant future
Exclamation Please help! Ultrasonic dashboard display.
The picture explains it pretty well, I need to see the value of analog input 2 on the dashboard to the thousands or 10 thousands place.
Thanks!
Unread 04-03-2011, 21:52
Re: Please help! Ultrasonic dashboard display.
Have you played with the display format yet?
For instance, in your Dashboard project right-click on the analog field and choose Properties.
Go to the Display Format tab.
Change Precision Type to "Digits of Precision"
Play with the # of digits
Remember to expand the display field itself, so it has room to put your digits.
Unread 04-03-2011, 22:50
FRC #3476
Smile Re: Please help! Ultrasonic dashboard display.
Thanks for the help, I'll try that.
Unread 05-03-2011, 16:21
I'm not sure you'll be able to select and edit that piece of the default dashboard until you ungroup everything in that section. There's a drop-down menu at the right end of the tool bar that holds the group and ungroup commands (plus others).
Unread 06-03-2011, 20:27
gnunes gnunes is offline
FRC #1391 (Metal Moose)
gnunes has a spectacular aura aboutgnunes has a spectacular aura aboutgnunes has a spectacular aura about
Do you need to see this in competition? If so, then you should make a custom Dashboard project. You can put your own custom indicator on the front panel and make it as large as you like, with as many digits as you like. You can even make it change color or start blinking if the value crosses some threshold.
I found this tutorial really useful in making my own dashboard:
http://decibel.ni.com/content/docs/DOC-14704
