Go to Post On a team, saying "it's not my job" is simply not acceptable. - dlavery [more]
Unread 05-03-2011, 19:14
Re: Liquid Gases on Robot as coolant
Originally Posted by nighterfighter View Post
What could go wrong!
I believe that's supposed to be:
What could go wrong... go wrong... go wrong...
Unread 05-03-2011, 19:17
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Well, at least it isn't electrically conductive.
Sure, it might make everything brittle and shatter, but at least you won't have a short!
Unread 05-03-2011, 20:40
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
how is your electronic board heating up in the first place, nothing should overheat except perhaps a breaker, batteries can get a little warm too i guess.
Unread 05-03-2011, 21:42
KC1AJT's Avatar
KC1AJT KC1AJT is offline
Head Mentor
AKA: Patrick
FRC #6617 (Bellinghan High School Black Hawks Robotics Club)
KC1AJT is an unknown quantity at this point
team 20 was actually packing ice on their motors (or i assume it was the motors) between the matches in the finals at BAE
Mentor - Team 6617
_____________________________________________
Student Years - Team 61
2011 Boston Regional
2011 BAE Systems/Granite State Regional
2010 Northeast Utilities FIRST Connecticut Regional Finalist
2010 Boston Regional
2009 Archimedes Division
2009 Connecticut Regional
2009 Boston Regional Regional Winner
Unread 06-03-2011, 14:17
DonRotolo's Avatar
Back to humble
FRC #0832
This wins this week's award for "Most Bizarre Thread".
Carry on.
Unread 06-03-2011, 15:01
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Originally Posted by james7132 View Post
Is it legal to have liquid gases (nitrogen, helium, etc) as a coolant on our minibot or hostbot?
I don't recall seeing liquid nitrogen, helium, etc on the list of approved materials for minibots.
The pneumatic compressor would probably move a lot more air in a small area than the muffin fans....
Unread 06-03-2011, 15:20
DonRotolo's Avatar
Back to humble
FRC #0832
A Peltier Device would also move a lot of heat onto a heat sink, which could then use a fan to dump into atmosphere.
Not sure if a water-cooled system would be allowed, like they use in some computers.
Unread 06-03-2011, 17:26
<R02> ROBOT parts shall not be made from hazardous materials, be unsafe, or cause an unsafe condition. Items specifically prohibited from use on the ROBOT include (but are not limited to):
And the various rules in several sections that speak to damaging the playing field, floors, etc.
As unlikely as you think it might be, robot parts break, robots tip over, and other people are always present. Liquid gasses in any form pose such a hazard. Liquid coolants of any type cannot satisfy the above rules for safety and preventing damage to field or venue.
While teams will go to any length to try and cool motors between matches, any external method does little to remove the internal heat stored in the motor. The path for conduction of the heat in the armature is only through the two end bearings and brush assembly or from direct radiation to the case and magnet structure of the motor. Teams that use freeze spray, run the risk of the material used in making the spray cold, flushing lubricants from exposed motor bearings. Extremely cold surfaces will also condense humidity out of the air like on the outside of a cold drink. Use freeze spray with caution.
Unread 06-03-2011, 20:33
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Still, no ones answered what/why the circuitry is overheating in the first place. I feel that this should be the really issue here.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 06-03-2011, 20:40
Precisely. But the OP - James from Marietta - has not posted any follow-ups since his original post was made 27 hours ago.
Unread 06-03-2011, 22:29
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
I'm starting to suspect this thread was more of a gag than a serious question...
I can't think of anyway to heat something that much without breaking a few robot rules that way, but that could be a failure of imagination on my part.
Matt Krass
