Go to Post According to my father the hint should be released sometime next week, but he's never been the most trustworthy source of info.... - Lil' Lavery [more]
Unread 06-03-2011, 20:35
HarveyAce's Avatar
HarveyAce HarveyAce is offline
FRC #3329 (CAMBots)
HarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant future
Motor for arm: what should be used when?
We are using two window motors in tandem to power the upper half or our arm. We were running into problems with them going really slow and not reaching past parallel with the ground, until we added a surgical tubing counterbalance . after that, we couldn't control it going down, because it went way too fast, and we put them on Victors instead of spikes and had to manually drop the voltage to make them go at a more controllable speed. any other solutions to this problem?
Also I was starting this thread to compile a list of what motors are good for what applications, and how to implement each in the applications. For example, one might say that FP's can be used for manipulators, but they are easily back driven, so explain how to use them without them back driving. Just a quick example. Hope this becomes a good resource for those that need a quick reference!
"Though I fly through the Valley of Death I shall fear no evil, for I am at 80,000 feet and climbing."
Unread 06-03-2011, 21:35
clayman's Avatar
clayman clayman is offline
AKA: Clayton
FRC #3175 (Knight Vision)
clayman is an unknown quantity at this point
Re: Motor for arm: what should be used when?
We ran into the exact same problems with the window motors at the base our arm. Since we took out the locking pins and the motors were backdriving anyway, we swapped them out with a single cim on a toughbox. We have yet to test it, though (but we don't expect any issues). The other two joints on our arm are driven by single, unmodified window motors.
Unread 06-03-2011, 22:09
You seem to be saying that the output of the toughbox shaft will be driving the arm with no additional gearing. That's not what you meant to say, is it?
Unread 07-03-2011, 13:46
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
You might try setting the brake mode jumper on the Victors.
Unread 07-03-2011, 15:44
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Brake mode won't help unless they've removed the anti-backdrive pins from the window motors. Brake mode only engages when the motor is stopped, which is when the anti-backdrive pins also kick in. The fundamental issue is that the arm still isn't perfectly balanced and is still falling under its own weight. As long as that's the case, your arm is going to go down faster than up, because more torque is required to lift the arm. You're never going to completely even things out with surgical tubing either. If you arrange it and tension it to balance things when the arm's level, it's either going to pull too hard when you lower the arm below level or raise it above level. So if your arm works reasonably now, I recommend leaving well enough alone.
For the curious, the best bet for perfectly balancing it would be an actual counterweight on the arm, followed by a constant force spring mounted a reasonable distance from the pivot so the spring is always approximately vertical. But either is loads heavier and more complicated than some surgical tubing.
Unread 07-03-2011, 15:45
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Try adding more surgical tubing. More assistance will make it the same load in each direction, therefore keeping it from falling. If it just goes to fast in general, a victor/jag could work, but the better answer is ussualy to change your ratio.
As per the motor usage question...
The only "norm" in FIRST is CIMs on drive, and even that isn't followed by all teams (and doesn't need to be). After that, it depends on the application.
All the motors in this year's kit are great, pick the one you want to use, gear it approriately and you're good to go.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 07-03-2011, 15:47
2829ron 2829ron is offline
FRC #2829
2829ron will become famous soon enough2829ron will become famous soon enough
Please tell us how this works. We built our arm with the CIM and toughbox and were having problems getting it past about parallel with ground. May have been our batteries though. Please let us know what happens.
David
Unread 07-03-2011, 18:10
Originally Posted by 2829ron View Post
We built our arm with the CIM and toughbox and were having problems getting it past about vertical.
Let's say 90 degrees per second is the approximate arm speed you'd like at full motor voltage (speeds faster than this can be difficult to control, slower speeds may make you uncompetitive)
Let's say you've got the equivalent of 5 pounds at 6 feet from the pivot, or 30 foot-pounds of torque.
From these two numbers you can calculate the required mechanical power in watts:
90 degrees per second = 15 rpm
(15 rpm)*(30 ft-lb)/7.043 = 63.9 watts
Now using the motor curves, or this simple calculator, you can find that the CIM motor speed which generates 63.9 watts at 12 volts input is 5045 rpm. Since 5045 is 95% of the CIM's free speed, it should run cool at this operating point.
Take the ratio of the motor rpm to the arm rpm to get the required gear ratio:
5045/15 = 336:1 gear ratio.
If you use a gear ratio much less than this, you will either get an arm which moves so fast that it is uncontrollable, or you will have to operate the motor far outside its design point which can cause overheating. The CIM is can tolerate a lot of abuse but it is not immune to burn-out.
Unread 07-03-2011, 23:32
FRC #2829
We used the sprockets from the wheels and put them on the arm. This is attached to a chain running to the toughbox.
David
P.s. Parallel to the ground not vertical
Unread 07-03-2011, 23:40
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
We use only 1 window motor to drive the 62" arm. Needless to say, it gets burning hot. So we put a heatsink with a fan on it (I don't know if it is legal)
Unread 08-03-2011, 01:32
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Which fan?
Unread 08-03-2011, 18:58
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Originally Posted by Tristan Lall View Post
Which fan?
Just some random one off of an old computer
Unread 08-03-2011, 19:18
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
You'll have to replace it with one provided in the KOP to be legal under <R45> and <R46>.
Unread 08-03-2011, 19:37
CallieJ's Avatar
CallieJ CallieJ is offline
The Girl With the Spirit Tattoos
FRC #1868 (Space Cookies)
Team Role: Scout
CallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to behold
We're running our arm on one Banebots 550 and one Fisher Price. We were going to use the Andy Mark Double Doozy but it wasn't available, so we designed and built our own custom gearbox. The internal reduction is 237:1 plus another approximately 3:1 reduction from the sprockets.
So far the motors have been getting warm but not hot under match level or higher stress environments. We did have to do a lot of work in software to keep the arm from sinking but even that doesn't seem to be putting too much strain on them.
2009,10,11 Silicon Valley Regional Finalists
2011 Silicon Valley Regional Chairman's Winners
2011 Sacramento Regional Champions
2011 Sacramento Regional Engineering Inspiration Award
2009 Silicon Valley Regional Engineering Inspiration Award
2006 Championships Judge's Award
www.spacecookies.org
Unread 08-03-2011, 19:58
Kyoshirin's Avatar
Kyoshirin Kyoshirin is offline
Renaissance Man
AKA: David
FRC #1188
Kyoshirin is an unknown quantity at this point
We have two window motors hooked up to a 20:3 (~7:1) gear ratio to a 40" upper arm, on which is attached another window motor hooked up by timing belt ~3:1 to a 33" lower arm with a pneumatic claw attached to the end adding length and weight. We never had any problems with our arm lifting, but we have four strands of surgical tubing just in case.
Prototypes ARE the final product.
Last edited by Kyoshirin : 09-03-2011 at 14:23. Reason: Had the gear ratios backwards and had wrong arm measurements.
