Manipulators
Being the student lead on my teams tube manipulator I was wondering:
What there any perticular designs which stood out this weekend? Any favorites? Any really unique designs or implementations? I'm not really looking for the best claw in the world. I'm just looking for other cool, generally effective designs to learn from. Pictures if you have them are great. Explainations, statistics, motors, weight, its all good stuff. Thanks in advance! |
Re: Manipulators
Team 16 and 148 both had great manipulators this weekend. The Bomb Squard's design is one of the coolest and most creative designs I have seen this year. The Robowranglers pretty much perfected the roller claw.
I assume you have seen them already but if not Team 16 Unveiling Team 148 Unveiling And video from their elimination matches |
Re: Manipulators
Team 131 C.H.A.O.S. at the GSR had a different sort of roller manipulator. They dubbed it the chainsaw. You can see it in their teaser: http://www.youtube.com/watch?v=mXzGe-eDVLU
It's essentially the bottom part of a roller claw, but longer. The chainsaw goes in the center hole of the tube, then they just put the chainsaw right up at the scoring peg and reverse the roller. They seemed to have quite a bit less trouble with dropping off the tube than many manipulators. |
Re: Manipulators
I like how 16's 'claw' adds more anecdotal evidence to the roller/pinchy claw debate. I also like how it seems to auto-align slightly so long as its center point is within the center diameters of the tubes (looks like surgical tubing that does the work).
My other favorite design that I saw in a webcast was 25's. I also saw this design in person during Battle O Baltimore 2007, though then it was implemented with hockey sticks. It is a simple inner-pinchy claw that comes togeter to a fine point for dropping down into the tube, then spreads out when it's time to pick up the tube. As implemented, it allows for a good deal of driver error (Triangle hole width - 2" or so) and also allows them to drive around as soon as the prongs are inside the tube, regardless of whether or not the tube is picked up yet. |
Re: Manipulators
Thanks for the replies.
I suppose I should share my own teams collector: It is a 16" wide 5lbs hinged roller claw. We use polyurthane belting to drive each of the four rollers (on dead axels) and to cover the front rollers to pull the tubes in. The top is basically aluminum angle and the back and bottom are basically polycarbinate L's which are forced open and closed via pneumatics. The front two rollers are made of polycarbinate tube and the back two are thinwall aluminum tubing. We also have a limit switch attached inside the claw to sense and automatically pick up tubes to minimize pickup time and make it easier for the drivers to pick up tubes without being able to see. Overall, we are very happy with it. It can handle both over-inflated tubes and under inflated tubes well, and allows for both quick and inaccurate ground pickup and scoring. As an added bonus it is very low maintance. This is a pretty good look at it and how it functions http://www.youtube.com/watch?v=jeUBHoelq4o about 2:00 minutes in. I would love to hear from other teams what design process they went through to end up at the claw they did. It seems every team came up with their own unique solution and implementation. Thanks again, Bryan Last edited by BJC : 07-03-2011 at 21:57. |
