Go to Post It doesn't matter to me where a FIRST local event is held, I'll be there! - Barry Bonzack [more]
Unread 07-03-2011, 13:46
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Motor for arm: what should be used when?
You might try setting the brake mode jumper on the Victors.
Unread 07-03-2011, 15:44
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Brake mode won't help unless they've removed the anti-backdrive pins from the window motors. Brake mode only engages when the motor is stopped, which is when the anti-backdrive pins also kick in. The fundamental issue is that the arm still isn't perfectly balanced and is still falling under its own weight. As long as that's the case, your arm is going to go down faster than up, because more torque is required to lift the arm. You're never going to completely even things out with surgical tubing either. If you arrange it and tension it to balance things when the arm's level, it's either going to pull too hard when you lower the arm below level or raise it above level. So if your arm works reasonably now, I recommend leaving well enough alone.
For the curious, the best bet for perfectly balancing it would be an actual counterweight on the arm, followed by a constant force spring mounted a reasonable distance from the pivot so the spring is always approximately vertical. But either is loads heavier and more complicated than some surgical tubing.
Unread 07-03-2011, 15:45
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Try adding more surgical tubing. More assistance will make it the same load in each direction, therefore keeping it from falling. If it just goes to fast in general, a victor/jag could work, but the better answer is ussualy to change your ratio.
As per the motor usage question...
The only "norm" in FIRST is CIMs on drive, and even that isn't followed by all teams (and doesn't need to be). After that, it depends on the application.
All the motors in this year's kit are great, pick the one you want to use, gear it approriately and you're good to go.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
