Go to Post I just want to see Aerial Assist again. Played on Lunacy regolith. With minibot poles. Which are on coopertition bridges. Is that too much to ask for? ;) - M. Lillis [more]
Unread 07-03-2011, 17:20
bearsomg bearsomg is offline
FRC #1511
bearsomg is an unknown quantity at this point
Custom Driverstation
Has anyone managed to develop a custom driver station (not the dashboard, the full driver station) in a language other than labview? If so, could you send me the source code please? I've been trying to make our own custom driver station in C#.NET but I can't seem to find how to structure the packets that are being sent to the robot.
My final goal with this is to be able to write an iPhone app that works just like the normal driver station so that we can use it with our normal robot code.
Thanks!
Justin
FIRST Team 1511 Rolling Thunder
Unread 08-03-2011, 11:29
Re: Custom Driverstation
You might want to contact Ben Abraham of Team 3357. He's on Chief Delphi as mobilegamer999, and wrote an iPhone app that does what you propose. See this thread for information.
Unread 10-03-2011, 15:35
A couple things to keep in mind.
At this point it is not legal to use a custom driver station at a FIRST competition.
As you write the driver station software, think through the safety issues. Your code will now be directly responsible for much of what the robot does. If the app crashes and stops communicating, the system watchdog will shutdown the outputs. If your app continues sending commands, the robot will do what it is told -- whatever that is. Test it thoroughly, especially before using it around crowds of people or letting others drive it.
Greg McKaskle
Unread 14-03-2011, 18:29
ShotgunNinja's Avatar
ShotgunNinja ShotgunNinja is offline
Programming Mentor, FRC 4247
AKA: Nicholas Iannone
FRC #4247 (CougarBOTS)
ShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the rough
There is a project called the ZomB Dashboard on http://firstforge.wpi.edu/ that you should check out, and I know a guy named Eric Haskins, from FRC #1103, who fully reimplemented the FRC Communication Protocol for the Arduino Mega 2560 for our college-level robotics competition. We have some partial code for you to look at here:
Driver Station (in C#/.NET!)
http://code.google.com/p/scoe-robotics-driver-station/
Team #2970 Alum
Team #1652 Alum
2006: School Mascot for Team 1652
2007-2008: Programmer for Team 1652 (Robot Mafia)
2009: Programmer on Team 1652 (Robot Mafia), Programmer on Team 2970 (eSchool eBots)
2010-2016: Volunteer, Wisconsin Regional
2017: Programming Mentor, FRC 4247 (CougarBOTS, Obama SCTE, Milwaukee, WI)
Unread 22-03-2011, 16:32
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Originally Posted by ShotgunNinja View Post
There is a project called the ZomB Dashboard on http://firstforge.wpi.edu/sf/projects/zombdashboard that you should check out,
More specifically, the DS plugin source, located in DriverStation.cs in the ZomB.DriverStation folder: source
Watchdog.Kill();
