Go to Post Analysis is a tool. Like any other tool you need to figure out where and when to use it. That's the tricky part. - ChrisH [more]
Unread 07-03-2011, 17:31
Slothbron's Avatar
Slothbron Slothbron is offline
AKA: Nathan
FRC #3216 (Missoula Robotics Team)
Slothbron is an unknown quantity at this point
Camera responding to wrong joystick buttons
Ok so I thought I programed the camera to respond to the 2,3,4,5 buttons on one joystick and on the other joystick I have stuff already assigned to these buttons. But when I press the buttons assigned to the other stuff the camera also respond to it. But does not respond if I press buttons 2,3,4,5 on the joystick I assigned it. I also have attached the program so you can look at it if needed. Any help would be greatly appreciated.
MRT 3216
2010- Salt lake City Highest Rookie Team seed
Unread 07-03-2011, 18:32
Re: Camera responding to wrong joystick buttons
It looks like you have a space after "joystick 2". If you don't have a corresponding space in begin where you set the device reference, you have a problem. I think it may be possible for an invalid joystick device reference to reference the joystick 1.
Unread 07-03-2011, 22:59
Also, check the joystick positions on the Driver station Setup tab.
push a button and the USB it's associated with will turn blue.
Make sure the camera joystick is where you expect it to be.
