Go to Post make sure to make it look really cool, it makes it easier for teams to remember you, which comes in handy for alliance selections ;) - Holtzman [more]
Unread 07-03-2011, 11:44
SM987 SM987 is online now
AKA: Stephen McKinney
FRC #0987 (The High Rollers)
SM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond repute
Question Code not Properly Downloading
We're having an interesting problem on our practice bot that we hope doesn't carry over to the competition bot.
When we load code with different autonomous routines, only one in about 10 downloads "works", whether we download wireless or directly via ethernet. We've tried reimaging the cRio and even swapped it for another cRio.
We're certain it isn't a code issue, as we even commented out everything but a basic "drive straight" command and it failed to function. When we load an old autonomous routine that worked, it doesn't function properly. Making no changes to code, if we load it a few more times, testing it between loads, we get lucky and it works maybe 1 in 10-15 times.
We are thinking the code is somehow being corrupted during load, but have tried both wireless and wired downloads. We have also considered perhaps faulty Jaguars. It seems to be limited to autonomous function, but we did have a similar issue with tele-op during the build where we thought we had a code issue, so we changed the code a few time to no avail; when we loaded the original unrevised code back on it inexplicably worked.
Perhaps it could be issues with the laptop and windriver? Has anyone experienced something similar?
Unread 07-03-2011, 11:59
Re: Code not Properly Downloading
What programming language?
Perhaps you have an uninitialized variable that keeps the program from functioning as desired "most" of the time, until random factors align and it works.
Unread 07-03-2011, 12:59
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
What symptoms do you have to say its not working? To confirm, I'd recommend adding some console output (printf() in C++) that just says "Test #1" or something to your main loops, and then keep changing and redownloading, if it consistently prints the different messages, your problem is actually in code elsewhere, if you experience inconsistent messages, it may still be code, or it may be a legitimate download problem. (Don't you love technology?)
Matt
Matt Krass
Unread 07-03-2011, 13:04
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
[quote=SM987;1035894]We've tried reimaging the cRio and even swapped it for another cRio.[/code]
This makes me think code.
Nonetheless, post code here.
  1. Re-install WindRiver
  2. Install all updates
  3. Deploy code with the Run or Debug dialog, this will pop up with any virtual table errors etc
Unread 07-03-2011, 13:10
Matt Krass's Avatar
AKA: Dark Ages
I agree it sounds like it's probably not a download problem, basic code not working sounds like it may be hardware. I think if they try my printf() test we'll know for sure, but I'd look at the Jaguar connections, are they secure? Are you using CAN? Properly terminated? or is it PWM? and is your sidecar properly powered? DSCs with weird power wiring can magically switch between working and not in my experience.
Matt
Matt Krass
Unread 07-03-2011, 13:46
Let's see, I'll try and post the code here below. Haven't tried the printf test but have entered debug mode with the robot on blocks and I believe it appeared to follow the code appropriately, but the robot did not respond accordingly. Pretty sure we don't have any uninitialized variables, but I just took this on today. I'll be taking a closer look at the problem today after school and post the results here. Probably will start with using a different computer/windriver reinstall. Thanks for the help.
BTW, this year the students and mentors have been collaborating with code via bitbucket.org. We highly recommend it for tracking changes/reaching mentors at work etc.
Here's the code:
#include "WPILib.h"
#include "Target.h"
#include "DashboardDataSender.h"
#include "Dashboard.h"
#include "Math.h"
const float ARM_MINIMUM_ROTATION = 7.0f; //7.0f;        // don't ever drive the arm lower than this!
const float ARM_MAXIMUM_ROTATION = 650.0f;
const int ARM_PICKUP_PRESET = 135;
const int ARM_HIGH_GOAL_PRESET = 430;
const float ARM_PROPORTIONAL_CONSTANT = 0.0075f;
const int AUTO_ROTATION_START = 345;
const int AUTO_ROTATION_START_FORK = 330;
const int AUTO_ROTATION_SCORE_HIGH = 350;
const int AUTO_ROTATION_LOWER = 50;
const int AUTO_FULL_SPEED_MOVE_ENCODER_TICKS = 2000;  //2500 is total ticks start to end
const float AUTO_CLAW_REJECT_SECONDS = 1.5f;
const float AUTO_BACKUP_TIME = 5.0f;
const float AUTO_BACKUP_SECONDS = 4.0f;
const int AUTO_BACKUP_TICKS = 2200;
const int AUTO_TURN_TICKS = 520;
const float CLAW_CAPTURE_SPEED = 0.6f;
const float CLAW_REJECT_SPEED = 0.3f;
const float CLAW_ROTATION_SPEED = 0.3f;
const float AUTO_CLAW_REJECT_SPEED = .2f;
UINT32 Auto_End_Line;
UINT32 Auto_End_Line_Fork;
const float MINIBOT_AUTO_DEPLOY_VOLTAGE = 4.5f;
const float MINIBOT_AUTO_DEPLOY_SECONDS = 110.0f;
//#define MINIMUM_SCORE 0.01
double outputValue;
const UINT32 DETECTSLINE = 1;
const UINT32 LEFT_SENSOR_CHANNEL = 10;
const UINT32 CENTER_SENSOR_CHANNEL = 11;
const UINT32 RIGHT_SENSOR_CHANNEL = 12;
const float AUTO_SPEED_LOW = 0.8f;
const float AUTO_SPEED_FULL = 1.0f;
UINT32 LeftSensorReading;
int XL;
class SamplePIDOutput : public PIDOutput {
public:
        SamplePIDOutput(RobotDrive *base) {
                m_base = base;
        void PIDWrite(float output) {
                m_base->ArcadeDrive(0.0, output);
                outputValue = -output;
private:
        RobotDrive *m_base;
 * Demo that demonstrates tracking with the robot.
 * In Teleop mode the robot will drive using a single joystick plugged into port 1.
 * When the trigger is pressed, the robot will turn to face the circular target.
 * This demo uses the AxisCamera class to grab images. It finds the target and computes
 * the angle to the target from the center of view in the camera image. It then computes
 * a goal correction angle and uses the gyro to turn to that heading. The gyro correction
 * is done using the PID class to drive the robot to the desired heading.
 * The coefficients for the PID loop will need to be tuned to match the CG and weight of
 * your robot as well as the wheel and driving surface types.
 * As an added bonus, the program also sends robot status information to the LabVIEW sample
 * dashboard as well as camera annotation to show the targets that the robot is currently
 * seeing.
class RobotDemo : public SimpleRobot {
//      RobotDrive *base;
//      Joystick *stick; // only joystick
        DigitalInput *armUpperLimit;    // arm upper limit switch
        DigitalInput *armLowerLimit;    // arm lower limit switch
        AnalogChannel *armUpperLimit_ANALOG;
        AnalogChannel *armLowerLimit_ANALOG;
        Joystick *rightStick;                   // joystick 1 (arcade stick or right tank stick)
        Joystick *leftStick;                    // joystick 2 (tank left stick)
        Joystick *armStick;                             // joystick 3 to control arm
        DriverStation *ds;                              // driver station object
        Jaguar *LeftDrive;
        Jaguar *RightDrive;
        Jaguar *ArmRotation;
        Jaguar *ArmExtension;
        Jaguar *ClawTop;
        Jaguar *ClawBottom;
        Encoder *LeftDriveEnc;
        Encoder *RightDriveEnc;
        Encoder *ArmRotationEnc;
        Encoder *ArmExtensionEnc;
        Compressor *compressor;
        Solenoid *ShifterHigh;
        Solenoid *ShifterLow;
        Solenoid *EndGameIn;
        Solenoid *EndGameOut;
        Solenoid *DeploymentOut;
        Solenoid *DeploymentIn;
        DashboardDataSender *dds;
        PIDOutput *pidOutput;
        Gyro *gyro;
        DigitalInput *LeftLineSensor;
        DigitalInput *CenterLineSensor;
        DigitalInput *RightLineSensor;
        DigitalInput *ArmSensor;
        float LastExtensionCommand;
        AnalogChannel *Minibot_Deploy_Light_Sensor;
        //Timer Minibot_Deploy_Timer;
        bool Minibot_Deploy_Enabled;
        // Arm Position (angle) control
        float CurrentArmPosition;
        float TargetArmPosition;
        float ArmPosition_error;
        float ArmPositionCommand;
        float ArmPositionConstant;
        float CurrentArmStick;
        float PreviousArmStick;
        float ArmPosMaxCmd;
        int Previous_Sensor_Detect;
        int AutoSeq;
        Timer AutoStateTimer;
        int AutoState;
        int AutoLeftEncoderStart;
        int AutoRightEncoderStart;
        int left_drive_count;
        int right_drive_count;
        enum                                                    // Driver Station jumpers to control program operation
        { ARCADE_MODE = 1,                              // Tank/Arcade jumper is on DS Input 1 (Jumper present is arcade)
          ENABLE_AUTONOMOUS = 2,                // Autonomous/Teleop jumper is on DS Input 2 (Jumper present is autonomous)
        } jumpers;
public:
        RobotDemo(void)
/*              // initialize all variables
                base = new RobotDrive(1, 2);
                base->SetInvertedMotor(RobotDrive::kRearLeftMotor, true);
                base->SetInvertedMotor(RobotDrive::kRearRightMotor, true);
                stick = new Joystick(1);
                pidOutput = new SamplePIDOutput(base);
                base->SetExpiration(0.5);
                gyro = new Gyro(1);
                dds = new DashboardDataSender();
                ds = DriverStation::GetInstance();
                rightStick = new Joystick(1);                   // create the joysticks
                leftStick = new Joystick(2);
                armStick = new Joystick(3);
                armUpperLimit = new DigitalInput(8);    // create the limit switch inputs
                armLowerLimit = new DigitalInput(9);
                armUpperLimit_ANALOG = new AnalogChannel(1);
                armLowerLimit_ANALOG = new AnalogChannel(2);
                Minibot_Deploy_Light_Sensor = new AnalogChannel(3);
                LeftDrive = new Jaguar(1);
                RightDrive = new Jaguar(2);
                ArmRotation = new Jaguar(3);
                ArmExtension = new Jaguar(4);
                ClawTop = new Jaguar(5);
                ClawBottom = new Jaguar(6);
                LeftDriveEnc = new Encoder(2,3);
                RightDriveEnc = new Encoder(4,5);
                ArmRotationEnc = new Encoder(6,7);
                ArmExtensionEnc = new Encoder(13,14);
                compressor = new Compressor(1,1);       //Pressure Switch, Compressor Relay
                compressor->Start();
                ShifterHigh = new Solenoid(8,1);
                ShifterLow = new Solenoid(8,2);
                EndGameIn = new Solenoid(8,4);
                EndGameOut = new Solenoid(8,5);
                DeploymentOut = new Solenoid(8,7);
                DeploymentIn = new Solenoid(8,8);
                LeftLineSensor = new DigitalInput(LEFT_SENSOR_CHANNEL);
                CenterLineSensor = new DigitalInput(CENTER_SENSOR_CHANNEL);
                RightLineSensor = new DigitalInput(RIGHT_SENSOR_CHANNEL);
                ArmSensor = new DigitalInput(13);
                //Update the motors at least every 100ms.
//              myRobot.SetExpiration(0.1);
                GetWatchdog().SetExpiration(100); //0.5); //100);
                // Arm Rotation Control Variables
                CurrentArmPosition = 0.0f;
                TargetArmPosition = 0.0f;
                ArmPosition_error = 0.0f;
                ArmPositionCommand = 0.0f;
                ArmPositionConstant = ARM_PROPORTIONAL_CONSTANT;                // this controls how fast the arm reacts
                CurrentArmStick = 0.0f;
                PreviousArmStick = 0.0f;
                ArmPosMaxCmd = 1.0f;
                ArmRotation->Set(0.0);
                //ArmExtensionEnc->Get(),
        void Dashboard_Update(void)
                dds->sendIOPortData
                        LeftDriveEnc->Get(),
                        RightDriveEnc->Get(),
                        LeftLineSensor->Get(),
                        CenterLineSensor->Get(),
                        RightLineSensor->Get(),
                        ArmRotationEnc->Get(),
                        TargetArmPosition,
                        ArmPosition_error,
                        ArmPositionCommand,
                        ds->GetAnalogIn(1),   //slider
                        armUpperLimit->Get(),
                        armLowerLimit->Get(),
                        armUpperLimit_ANALOG->GetVoltage(),
                        armLowerLimit_ANALOG->GetVoltage(),
                        Minibot_Deploy_Light_Sensor->GetVoltage(),
                        AutoSeq,
                        AutoState
        void ArmExtensionPref()
                if(ds->GetDigitalIn(6) == 1)
                        ArmExtension->Set(armStick->GetY());
                else
                        ArmExtension->Set(armStick->GetTop());
        void ArmRotationPref()
                        ArmRotation->Set(armStick->GetX());
                else
                        ArmRotation->Set(armStick->GetY());
        void UpdateArm()
                CurrentArmPosition = (float)ArmRotationEnc->Get();
                if(TargetArmPosition > 0)
                        ArmPosition_error = TargetArmPosition - CurrentArmPosition;
                        ArmPositionCommand = ArmPosition_error * ArmPositionConstant; // +.1f;
                        PreviousArmStick = CurrentArmStick;
                        CurrentArmStick = armStick->GetX();
                        // Clamp the command given to the arm motor
                        if(ArmPositionCommand > ArmPosMaxCmd)
                                ArmPositionCommand = ArmPosMaxCmd;
                        if(ArmPositionCommand < -ArmPosMaxCmd)
                                ArmPositionCommand = -ArmPosMaxCmd;
                        if(fabs(PreviousArmStick) > 0.1f)
                                if(fabs(CurrentArmStick) < 0.1f)
                                        // User just stopped using joystick, tell arm controller
                                        // to hold at current position
                                        TargetArmPosition = CurrentArmPosition;
                                else
                                        // User is still using the joystick, so set the target
                                        // to zero so the arm control code doesn't do anything
                                        TargetArmPosition = 0;
                else
                        ArmPositionCommand = armStick->GetX();
                // Ok, the command has been computed, now protect the ends of
                // the arm's motion (don't let the user drive past either limit)
                // If the manual override button is pressed, skip this clamping step
                if ((CurrentArmPosition <= ARM_MINIMUM_ROTATION) && (armStick->GetRawButton(7) == 0))
                        // we're at the lower limit, only allow zero or positive commands
                        ArmPositionCommand = max(0.0f,ArmPositionCommand);
                else if ((CurrentArmPosition >= ARM_MAXIMUM_ROTATION) && (armStick->GetRawButton(7) == 0))
                        ArmPositionCommand = min(ArmPositionCommand,0.0f);
                ArmRotation->Set(ArmPositionCommand);
                //ArmRotation->Set(0);
        void SetArm(int Position)
                TargetArmPosition = Position;
        void UpdateArmExtension(float command)
                bool UpperLimitReached = (armUpperLimit_ANALOG->GetVoltage() < 3.0f);
                bool LowerLimitReached = (armLowerLimit_ANALOG->GetVoltage() > 3.0f);
                if(armStick->GetRawButton(7) == 1)
                        UpperLimitReached = false;
                float ExtensionCmd = command;
                if (UpperLimitReached)
                        if (ExtensionCmd > 0.0f) ExtensionCmd = 0.0f;
                if (LowerLimitReached)
                        if (ExtensionCmd < 0.0f) ExtensionCmd = 0.0f;
                ArmExtension->Set(ExtensionCmd);
                //ArmExtension->Set(0);
        void UpdateDriving()
                LeftDrive->Set(leftStick->GetY());
                RightDrive->Set(-rightStick->GetY());
        void StartEncoders()
                LeftDriveEnc->Reset();
                RightDriveEnc->Reset();
                //Enc->Reset();
                ArmRotationEnc->Reset();
                LeftDriveEnc->Start();
                RightDriveEnc->Start();
                ArmExtensionEnc->Start();
                ArmRotationEnc->Start();
        void Follow_Line(bool Fork, int Left_Right,float speed_scale) //Left = 0; Right = 1; Straight = 2;
                if((LeftLineSensor->Get()==1)&&(CenterLineSensor->Get()==1)&&(RightLineSensor->Get()==1))
                        LeftDrive->Set(0.0f);
                        RightDrive->Set(0.0f);
                        Auto_End_Line = 1;
                if((LeftLineSensor->Get() ==  1) && (CenterLineSensor->Get() == 1))
                        Auto_End_Line_Fork = 1;
                else if((LeftLineSensor->Get() ==  1) && (RightLineSensor->Get() == 1))
                else if((CenterLineSensor->Get() ==  1) && (RightLineSensor->Get() == 1))
                if(Auto_End_Line == 0)
                        if(LeftLineSensor->Get() == 1)
                                Previous_Sensor_Detect = 1;
                                //LeftDrive->Set(-AUTO_SPEED_LOW);               //<- That is forward
                                //RightDrive->Set(AUTO_SPEED_FULL);
                        if(RightLineSensor->Get() == 1)
                                Previous_Sensor_Detect = 2;
                                //LeftDrive->Set(-AUTO_SPEED_FULL);
                                //RightDrive->Set(AUTO_SPEED_LOW);
                        if(CenterLineSensor->Get() == 1)
                                Previous_Sensor_Detect = 3;
                        if(Previous_Sensor_Detect == 1)
                                LeftDrive->Set(-AUTO_SPEED_LOW*speed_scale);
                                RightDrive->Set(AUTO_SPEED_FULL*speed_scale);
                        if(Previous_Sensor_Detect == 2)
                                LeftDrive->Set(-AUTO_SPEED_FULL*speed_scale);
                                RightDrive->Set(AUTO_SPEED_LOW*speed_scale);
                        if(Previous_Sensor_Detect == 3)
                else if(Auto_End_Line == 1)
        void Read_Auto_Switch(void)
                // Check the auto sequence number only in disabled mode!  During auto, all
                // DS inputs are zeroed.
                int seq = 0;
                bool Dec1 = !ds->GetDigitalIn(1);
                bool Dec2 = !ds->GetDigitalIn(3);
                bool Dec4 = !ds->GetDigitalIn(5);
                bool Dec8 = !ds->GetDigitalIn(7);
                if (Dec1 == true)
                        seq += 1;
                if (Dec2 == true)
                        seq += 2;
                if (Dec4 == true)
                        seq += 4;
                if (Dec8 == true)
                        seq += 8;
                if (seq != 0) AutoSeq = seq;
        virtual void Disabled()
                Read_Auto_Switch();
        void Auto_Goto_State(int new_state)
                AutoState = new_state;
                AutoStateTimer.Reset();
                AutoLeftEncoderStart = LeftDriveEnc->Get();
                AutoRightEncoderStart = RightDriveEnc->Get();
        void AUTO_one()
                if(AutoState == 0)
                    float speed_scale = 1.0f;
                    SetArm(AUTO_ROTATION_START);
                        UpdateArmExtension(-.5);
                        // watch encoders and slow down when we get close!
                        // in low gear, about 2500 ticks from start to end
                        if (left_drive_count > AUTO_FULL_SPEED_MOVE_ENCODER_TICKS)
                                speed_scale = 0.6f;
                        Follow_Line(false,3,speed_scale);
                                Auto_Goto_State(1);
                else if (AutoState == 1)
                        SetArm(AUTO_ROTATION_SCORE_HIGH);
                        if(abs((int)ArmPosition_error) < 60.0f)  //HACK!
                                Auto_Goto_State(2);
                else if (AutoState == 2)
                        // release tube
                        if (AutoStateTimer.Get() < AUTO_CLAW_REJECT_SECONDS)
                                ClawTop->Set(-AUTO_CLAW_REJECT_SPEED);
                                ClawBottom->Set(-AUTO_CLAW_REJECT_SPEED);
                                UpdateArmExtension(0.5);
                        else
                                Auto_Goto_State(3);
                                ClawTop->Set(0);
                                ClawBottom->Set(0);
                else if (AutoState == 3)
                        // back up for a few seconds
                        if (AutoStateTimer.Get() < AUTO_BACKUP_SECONDS) // abs(left_drive_count) > 200)
                                LeftDrive->Set(1.0f);               //<- That is forward
                                RightDrive->Set(-1.0f);
                                if (AutoStateTimer.Get() > 2.0f)
                                        SetArm(AUTO_ROTATION_LOWER);  // lower arm after 2 sec
                        else
                                LeftDrive->Set(0);
                                RightDrive->Set(0);
                                Auto_Goto_State(4);
                else if (AutoState == 4)
                        if (abs(left_drive_count) < AUTO_TURN_TICKS)
                                RightDrive->Set(-AUTO_SPEED_LOW);
                        else
                                LeftDrive->Set(0);
                                RightDrive->Set(0);
                        Auto_Goto_State(5);
        void AUTO_two_fork(int rightleft) //o = right 1 = left
                if(AutoState == 0)
                        SetArm(AUTO_ROTATION_START_FORK);
                        //if (left_drive_count > AUTO_FULL_SPEED_MOVE_ENCODER_TICKS)
                        //      speed_scale = 0.5f;
                        Auto_End_Line = 0;
                        if(left_drive_count > 1640)
                                Auto_Goto_State(1);
                        if((CenterLineSensor->Get() == 1) && (RightLineSensor->Get() == 0) && (LeftLineSensor->Get() == 0))
                                Auto_Goto_State(2);
                        else
                                if(rightleft == 0)
                                        LeftDrive->Set(-0.35f);
                                        RightDrive->Set(-0.2f);
                                else
                                        LeftDrive->Set(0.2f);
                                        RightDrive->Set(.35f);
                        // release tube
                        if (left_drive_count < 250)
                                Follow_Line(0,0,.5f);
                        else
                                Auto_Goto_State(3);
                        if(rightleft == 0)
                                if (left_drive_count > -40)
                                        LeftDrive->Set(.3f);
                                        RightDrive->Set(.3f);
                                else
                                        Auto_Goto_State(4);
                        else if(rightleft == 1)
                                if (right_drive_count > -40)
                                        LeftDrive->Set(-.3f);
                                        RightDrive->Set(-.3f);
                                else
                                        Auto_Goto_State(4);
                        if(left_drive_count < 240)
                        else
                                Auto_Goto_State(5);
                else if(AutoState == 5)
                        else
                                Auto_Goto_State(6);
        void Auto_Hack(void)
                //Follow_Line(false,3,1.0f);
                Dashboard_Update();
                //UpdateArm();
        void Autonomous(void)
                GetWatchdog().SetEnabled(false);
                StartEncoders();
                // make sure we're in low gear
                //ShifterHigh->Set(true);
                //ShifterLow->Set(false);
                TargetArmPosition = 0; // clear out any arm command
                AutoStateTimer.Start();
                if (ds->GetDigitalIn(ENABLE_AUTONOMOUS) == 1)   // only run the autonomous program if jumper is in place
                        AutoState = 0;
                        Auto_End_Line = 0;
                        Auto_End_Line_Fork = 0;
                        while(IsAutonomous() == true)
                                left_drive_count = LeftDriveEnc->Get() - AutoLeftEncoderStart;
                                right_drive_count = RightDriveEnc->Get() - AutoRightEncoderStart;
                                Dashboard_Update();
                                UpdateArm();
                                //Auto_Hack();
                                //AUTO_one();
                                if(AutoSeq == 1)
                                        AUTO_one();
                                else if(AutoSeq == 2)
                                        AUTO_two_fork(0);
                                else if(AutoSeq == 3)
                                        AUTO_two_fork(1);
                                GetWatchdog().Feed();
                UpdateArmExtension(0.0);
                GetWatchdog().SetEnabled(true);
                // high gear after auto
                //ShifterHigh->Set(false);
                //ShifterLow->Set(true);
         * Main test program in operator control period.
         * Aquires images from the camera and determines if they match FRC targets.
        void OperatorControl(void) {
                 * Set up the PID controller with some parameters that should be pretty
                 * close for most kitbot robots.
                // Create and set up a camera instance. first wait for the camera to start
                // if the robot was just powered on. This gives the camera time to boot.
                StartEncoders();
                //Minibot_Deploy_Timer.Reset();
                //Minibot_Deploy_Timer.Start();
                printf("Getting camera instance\n");
                AxisCamera &camera = AxisCamera::GetInstance();
                printf("Setting camera parameters\n");
                camera.WriteResolution(AxisCamera::kResolution_320x240);
                camera.WriteCompression(20);
                camera.WriteBrightness(0);
                // set sensitivity for the 2010 kit gyro
                gyro->SetSensitivity(0.007);
                // set MotorSafety expiration
                GetWatchdog().SetExpiration(1.0);
                // keep track of the previous joystick trigger value
//              bool lastTrigger = false;
                // loop getting images from the camera and finding targets
                printf("Starting operator control loop\n");
                Timer timer;
                timer.Start();
                while (IsOperatorControl())
                        Auto_End_Line =0;
                        Dashboard_Update();
                        LeftSensorReading = LeftLineSensor->Get();
                        UpdateDriving();
                        UpdateArm();
//                      UpdateArmExtension();
                        static bool ShifterToggle = false;
                        static int LastTrigger = 0;
                        int Trigger = rightStick->GetTrigger();
                        if ((Trigger == 1) && (LastTrigger == 0))
                                ShifterToggle = !ShifterToggle;
                        LastTrigger = Trigger;
                        if(ShifterToggle)
                        else
                        if(rightStick->GetRawButton(2) == 1)
                                EndGameOut->Set(false);
//                              EndGameOut->Set(true);
//                              EndGameIn->Set(false);
                        else
//                              EndGameOut->Set(false);
//                              EndGameIn->Set(true);
                        static bool DeploymentToggle = false;
                        static int LastButton = 0;
                        int Button = rightStick->GetRawButton(3);
                        if ((Button == 1) && (LastButton == 0))
                                DeploymentToggle = !DeploymentToggle;
                        LastButton = Button;
                        // Auto Deploy for MiniBot
//                      bool Auto_Deploy = ds->GetAnalogIn(1);
/*                      if (
                                        (Minibot_Deploy_Timer.Get() > MINIBOT_AUTO_DEPLOY_SECONDS)
                                        && (Minibot_Deploy_Light_Sensor->GetVoltage() > MINIBOT_AUTO_DEPLOY_VOLTAGE)
                                        && (Auto_Deploy == true)
                                DeploymentToggle = true;
                        if(DeploymentToggle)
                                DeploymentOut->Set(true);
                                DeploymentIn->Set(false);
                        else
                                DeploymentOut->Set(false);
                                DeploymentIn->Set(true);
                        UpdateArmExtension(armStick->GetY());
                        // Preset 1
                        if(armStick->GetRawButton(12)==1)
                                SetArm(ARM_PICKUP_PRESET);      // pickup height
                        // Preset 2
                        if(armStick->GetRawButton(11)==1)
                                SetArm(ARM_HIGH_GOAL_PRESET);   // high goal
                        if (armStick->GetTrigger() == 1)
                                ClawTop->Set(-CLAW_REJECT_SPEED);
                                ClawBottom->Set(-CLAW_REJECT_SPEED);
                                if (armUpperLimit_ANALOG->GetVoltage() < 3.0f)
                                        ArmExtension->Set(0.0f);
                                else
                                        ArmExtension->Set(1.0f);
                        else if (armStick->GetRawButton(2) == 1)
                                ClawTop->Set(CLAW_CAPTURE_SPEED);
                                ClawBottom->Set(CLAW_CAPTURE_SPEED);
                        else if (armStick->GetRawButton(3) == 1)
                                ClawTop->Set(-CLAW_ROTATION_SPEED);
                                ClawBottom->Set(CLAW_ROTATION_SPEED);
                        else if (armStick->GetRawButton(5) == 1)
                                ClawTop->Set(CLAW_ROTATION_SPEED);
                                ClawBottom->Set(-CLAW_ROTATION_SPEED);
                        else
                                ClawTop->Set(0.0);
                                ClawBottom->Set(0.0);
//                      ClawTop->Set(armStick->GetTop());
/*                      bool trigger;
                        // if trigger is pulled, the robot will run with standard arcade drive
                        // otherwise the robot will home towards the target.
                        if (trigger = stick->GetTrigger()) {
                                if (trigger != lastTrigger)                     // check if trigger changed
                                        turnController.Enable();
                                // if there's a fresh and we're at the previous target heading then
                                // get a camera image and process it
                                if (camera.IsFreshImage())
                                        timer.Reset();
                                        // get the gyro heading that goes with this image
                                        double gyroAngle = gyro->PIDGet();
                                        // get the camera image
                                        HSLImage *image = camera.GetImage();
                                        // find FRC targets in the image
                                        vector<Target> targets = Target::FindCircularTargets(image);
                                        delete image;
                                        if (targets.size() == 0 || targets[0].m_score < MINIMUM_SCORE)
                                                // no targets found. Make sure the first one in the list is 0,0
                                                // since the dashboard program annotates the first target in green
                                                // and the others in magenta. With no qualified targets, they'll all
                                                // be magenta.
                                                Target nullTarget;
                                                nullTarget.m_majorRadius = 0.0;
                                                nullTarget.m_minorRadius = 0.0;
                                                nullTarget.m_score = 0.0;
                                                if (targets.size() == 0)
                                                        targets.push_back(nullTarget);
                                                else
                                                        targets.insert(targets.begin(), nullTarget);
                                                dds->sendVisionData(0.0, gyro->GetAngle(), 0.0, 0.0, targets);
                                                        printf("No target found\n\n");
                                                else
                                                        printf("No valid targets found, best score: %f ", targets[0].m_score);
                                        else {
                                                // We have some targets.
                                                // set the new PID heading setpoint to the first target in the list
                                                double horizontalAngle = targets[0].GetHorizontalAngle();
                                                double setPoint = gyroAngle + horizontalAngle;
                                                turnController.SetSetpoint(setPoint);
                                                // send dashbaord data for target tracking
                                                dds->sendVisionData(0.0, gyro->GetAngle(), 0.0, targets[0].m_xPos / targets[0].m_xMax, targets);
                                                printf("Target found %f ", targets[0].m_score);
//                                              targets[0].Print();
                                        printf("Time: %f\n", 1.0 / timer.Get());
                        } else {
                                // if the trigger is not pressed, then do Arcade driving with joystick 1
                                        turnController.Disable();
                                base->ArcadeDrive(stick);
                        lastTrigger = trigger;
                        // send the dashbaord data associated with the I/O ports
                        dds->sendIOPortData();
START_ROBOT_CLASS(RobotDemo);
Unread 07-03-2011, 16:11
Matt Krass's Avatar
AKA: Dark Ages
[code]#include "WPI
At this point, I personally doubt very much your problem lies in code or the download process. Take a close look at the electronics, how are your Jaguars connected? Is everything connected properly?
Matt
Matt Krass
Unread 07-03-2011, 17:30
Hjelstrom's Avatar
Hjelstrom Hjelstrom is offline
FRC #0987 (High Rollers)
Hjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond repute
Hi Matt, I'm a mentor for the team and was trying to help figure this out this weekend. I don't think its a download problem, I think the crio has the code we downloaded and is running it. Here's why:
We added a "heartbeat" variable to the code that counts 0,1,2,3,0,1,2,3... and sent that variable to a graph on the labview dashboard. The heartbeat updates on the dashboard though occasionally I'll see it miss a number here and there (I'm assuming a dashboard packet can be lost occasionally, it doesn't seem to conincide with the robot's behavior). This proves that we're getting code downloaded and that it is running and not getting hung up anywhere.
We've attached with the debugger and stepped through the code and see nothing out of the ordinary. All variables seem to be what we expect, all logic flow goes exactly where we expect.
We're seeing things I can't explain. Such as, in the debugger, step over a line that tells both sides of the drivetrain to drive forward, on the robot, one side starts driving but the other doesn't, then *while still on the same line of code *break-pointed* in the debugger, the other side starts driving a few seconds later.
We have two jaguars on each side of the drivetrain, driven by a Y-cable for each side from the crio/digital sidecar (can't remember). We've seen one jag come on but not the other. In the code, there is only one jaguar object for each side of the drivetrain. (could this be the problem?)
In teleop, for some reason the problems are far less common. The only symptom in teleop is that different functions on the robot will occasionally briefly stop responding to control. For example the right side might stop working but the left still works and the arm still works. The drivers are calling these "cutouts" and claim that the main robot before ship never did this. We get them pretty regularly now.
We don't believe we're near any current limits. The arm uses a worm gear and its motor draws very little current and the drivetrain is in low-gear when testing this stuff.
Unread 07-03-2011, 18:02
Matt Krass's Avatar
AKA: Dark Ages
The heartbeat code is in effect the exact same thing I was looking for with printf(). This confirms its definitely not a download problem, and I don't suspect it is a code problem. By your description I think my original suspicion of hardware is accurate. Please verify your digital sidecar is properly powered (it should be receiving 12V on its main power connector, not 5V as most teams believe) and that all three power indicator lights come on bright on the sidecar.
Matt
Matt Krass
Unread 07-03-2011, 19:51
The sidecar was fine (LED's ok, and we tested voltages with multimeter, its getting 12v), we swapped it out for another sidecar just to be sure and repeated the process, checked all connections etc. Here's what's really weird: we'll run the same code multiple times, and it will do something different every time, somewhat related to what its supposed to do (i.e. sometimes delay up to 30s before driving a bit, then spitting out a tube; sometimes functioning perfectly). It's like it has a mind of its own. We're using 3 wire servo to the Jags (checked all the connections), we're really stumped. All that is left to eliminate is the power distribution board (which checks out ok via multimeter), and the Jags/connection to them, so maybe we will try swapping those out.
Could the Jags via servo cable be the issue? We have a Y cable going to each drive side and yet still sometimes you can hear it drag a CIM. My personal guess is that at least one Jag is bad, but I don't know if that could cause the other issues we are having. The students have noted that sometimes the Jags flash red when these issues arise which means there is a fault.
We'll keep working on it, no discoveries yet
Unread 07-03-2011, 20:02
Matt Krass's Avatar
AKA: Dark Ages
I personally have had nothing but trouble with PWM Y-cables. I would try using CAN, but this late in the season its a fairly hefty change. It's certainly doable though if you bring parts to your first event and find a team to help you. A good middle ground between Y cables and CAN is using dedicated PWM cables to each Jaguar. You'll need more PWM ports, but I find it is more reliable personally.
May I ask why you didn't use CAN to begin with? I understand it can kind of daunting at first glance, but I can assure you it's not very difficult under the surface. You can also make use of sync groups to make sure the Jags update together.
As far as another test goes, I would disconnect the motor outputs from the Jaguars, so they're powered, and being commanded, but not actually driving anything. Definitely run through the PWM calibration procedure (as outlined in the manual) and then, command the motors forward and back on each side and make sure all the Jaguars on each side are reacting the same way regarding lights and voltage output by multimeter. The voltages between the two jags may vary slightly, but it should be pretty close for the same command.
One 'trick' you can do, to make it a bit easier to watch the voltages, put a probe on each M+ for each set of Jaguars, then your multimeter will measure the voltage difference between the outputs, it should be pretty low, under 1V preferably. If its higher, it means the Jaguars aren't responding to the commands the same way, and if you haven't calibrated them yet, you should definitely do that.
Sorry if this didn't make much sense, a little sick at the moment....
Matt
Matt Krass
Unread 07-03-2011, 21:57
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Just to cover the obvious... You're undeploying any code before you run code in debug mode, correct? You can get weird things happening otherwise.
Also, have you tried running NetConsole to see if you're getting any error messages or anything? Not everything shows up in the diagnostic window.
Unread 08-03-2011, 00:09
Unhappy Re: Code not Properly Downloading
We avoided CAN for tradition I guess We may switch to it if for no other reason than to keep PWM's from falling out. It is more versatile we just overlooked it in this tough year.
We're making some headway. We completely disconnected the drive Jags and it functioned fine. Then connected one side at a time and it functioned fine. When we connected everything, same issues. The Jags are going into fault mode, but it is interesting; one going in to fault mode appears to chain reaction them sometimes, other times not. It could be the calibration. This might explain why the problem is more prevalent in autonomous where full ahead commands aren't subject to human input.
The problem is limited to the Jags or to the power distribution board.
Faults are caused by over-current or under voltage. I doubt we're drawing much current in low gear up on blocks. We see the voltage jump all over the place but haven't had issues in the past (sometimes driving with the compressor running and other motors running you will see the voltage drop to 8 or below).
Maybe there's a bad Jag in the mix somewhere. I'll post some more findings tomorrow.
Unread 08-03-2011, 01:07
Hjelstrom's Avatar
Thanks for the tip about netconsole. I didn't even know about that and it looks extremely useful. To date all of our output has gone through the dashboard which is cool but takes a while to write the c++ and then modify the labview wiring (have to log out, log in as developer, etc etc). We were undeploying whenever debugging but don't hesitate to mention anything even if it might seem obvious.
Unread 08-03-2011, 02:01
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
What it sounds like you're describing is what we were experiencing earlier.. We were having a problem where the robot would respond to commands for about a second, then our programming laptop would lose connection to the C RIO, then it would get it back for a second, and so on. It turns out we had a loop without a delay in it, om nom noming all the processing time.
I don't know if there's a way to measure the CPU usage in windriver, but I'd suggest trying to find that or double-checking your code that you don't have anything too strenuous.
