Go to Post A coin flip is a wonderful thing. Not because it makes the decision for you, but because when the coin is in the air, you realize what you really want. - rtfgnow [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 08-03-2011, 10:46
davidpoduska davidpoduska is offline
FRC #1188
davidpoduska is an unknown quantity at this point
Height of Mini Bot tower base
I can find CAD drawings of all the field parts but not the actual height of the base! I see it is 30 wide 1/2 inch plywood with a 1.75 inch hole and 8 - 2 x 6 supports but I do not know what is the floor to top of base height.
I didn't measure at the Kettering comp. as I assumed it would be easy to find but no such luck. I am assuming 12- 15 inches.
Thanks
1188
Unread 08-03-2011, 10:57
team 3311 team 3311 is offline
FRC #4057 (Klamath Basion Robotics)
team 3311 has a spectacular aura aboutteam 3311 has a spectacular aura about
Re: Height of Mini Bot tower base
Somewhere I read 12 inches.
Unread 08-03-2011, 10:59
Steve Kaneb's Avatar
Steve Kaneb Steve Kaneb is offline
That's what I always say
AKA: Alex
FRC #0190 (Gompei and the H.E.R.D.)
Steve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really nice
Send a message via AIM to Steve Kaneb
The base itself is 12" from the main carpet of the playing surface. There's a field protector that goes around the base, with a layer of carpet over it. The protector+carpet is about 1/4" higher than the main carpet. In addition, there is a gentle slope going up to the base of the tower, so that right next to the base is about 1/2" above the main carpet playing surface.
WPI District 2017 Volunteer Coordinator.
I'm not here to help.
Unread 08-03-2011, 11:14
Plan on a minimum of 11" so you're not disappointed...
Unread 08-03-2011, 12:50
FRC #1188
Thanks for your help.
