Go to Post Most of us are pretty friendly. - StephLee [more]
Unread 10-11-2002, 17:02
Matt VP's Avatar
Matt VP Matt VP is offline
#0074 (Hot Heads)
Matt VP is an unknown quantity at this point
Human Modelling
Hmm, still trying to figure out how to model the hand.
Any thoughts, Chris?
Matt VanderPloeg
AMD Fanboy From Hell
Team 74
Unread 10-11-2002, 20:11
Sunny Thaper Sunny Thaper is offline
None #0064 (The Gila Monsters)
Team Role: Animator
Sunny Thaper is an unknown quantity at this point
Send a message via AIM to Sunny Thaper
Cool
I am not Chris but I remember we had to make a hand too, we gave up later when we saw a nice one online, but we found it easier to model from the palm out using both mesh edit and patch model. I can't remember exactly what we did but what I would suggest is take a sphere and mash it into a pancake shape, then mesh edit the sides with soft select. Then convert it into an editable patch and do a similar method for each of the fingers. After you have modeled everything, attach and then weld the vertexes together.
SUNNY
Unread 10-11-2002, 23:07
Chris Nowak Chris Nowak is offline
Soudeska?
#0074
Chris Nowak is an unknown quantity at this point
Uhh....I think hes using Nurbs, if im not mistaken that looks a lot like Rhino. Anyway, I cant really give you much advice as Ive only ever really modeled heads...hmmmm.....
This is tough...Im trying to think of ways to do it and make it fit the fingers well but im having little luck. I'll get back to you once I've played with rhino a bit.
MSN Messenger - chris_nowak91@hotmail.com
Team 74 - Top Seeded Team in Galileo Division
Unread 11-11-2002, 00:20
Team Role: Animator
Cool
Well, I gave him instructions for a new model, not for what he has done so far. But I never liked nurbs anyway so I couldn't help you any more, sorry.
SUNNY
Unread 11-11-2002, 10:21
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
Because you made the fingers before you made the palm, I think the model might not bend well when you attach the two together... Next time, I'd suggest modeling the fingers and palm together as one hand. My favorite way of making hands is to make a palm-shaped polygon, extrude it, extrude fingers and a thumb from that, and use poly-editing tools and meshsmooth to make it into a hand. I use meshsmooth for everything... It's not as sophisticated as NURBS, though.
You could also make the palm from modified copies of the spline on the end of the arm (if it is a spline), until it reaches the fingers, and then just weld verticies to get the fingers attached. If you weld carefully, they should bend well enough.
Unread 12-11-2002, 20:16
Matt VP's Avatar
#0074 (Hot Heads)
Yes, this is rhino.
Here's the deal, I'm going to try to make the palm with nurbs then use a cutting tool to chop the areas where the fingers meet with it out. Then I'm going to use blends to make the palm attach to the fingers as well as the rest of the arm... If that doesn't work, I'll just start over and model the hand as one object.
Matt VanderPloeg
Team 74
Unread 12-11-2002, 20:18
Matt VP's Avatar
#0074 (Hot Heads)
Originally posted by Sunny Thaper
...I would suggest is take a sphere and mash it into a pancake shape, then mesh edit the sides with soft select.
Almost forgot to mention this: You're different
Matt VanderPloeg
Team 74
Unread 12-11-2002, 21:23
Team Role: Animator
Cool
And what's wrong with being different? I actually do want to try out rhino though, it looks really nice but I am not a big fan of nurbs so I don't know what to do.
SUNNY
Unread 13-11-2002, 13:17
team384_pat team384_pat is offline
team384_pat is on a distinguished road
I think it looks awesome!
Keep up the good work on the hand and make it look sweet!!
Illegal human player bin placement Mike Soukup General Forum 29 01-04-2003 21:17
What do your human players and mentors do? jonathan lall General Forum 4 30-03-2003 22:34
human player pads starting Soukup General Forum 9 21-02-2003 10:12
Q&A Discuss: human stacking CD47-Bot Extra Discussion 1 05-01-2003 01:57
How are your Drivers and Human players doing????????? archiver 2001 2 24-06-2002 00:33
