Go to Post The longer you play robots, the more you realize that it's not about the robots. - dtengineering [more]
Unread 08-03-2011, 14:57
jrz126 jrz126 is offline
jrz126 is an unknown quantity at this point
How To use Global variables and sequences
Whats the proper way to use global variables? I've used quite a few in my project to pass variables between subvi's. In another thread, (here), Greg said "you will get burned by parallel updates or race conditions."
I made sure I'm only writing the variables in one place. So I think I'm ok with the parallel updates.
I don't think I'd have an issue with a race condition. But if I did, how should it be handled?
Unread 08-03-2011, 15:46
Re: How To use Global variables and sequences
It is all about using the right tool for the right job. Are you sure you want a global? Would a queue, a notifier or a user event work better for your application?
User events notifiers and queues can be passed around to subVIs, which makes code re-use easier later.
A queue allows you to guarantee that you will get all the data across, but is typically one write/one read.
A notifier only pushes data when you are ready to read it - if the listener is busy, it (intenionally) drops the write on the floor.
A user event is one write/multi read, but harder to use.
A global is easy to use, but doesn't have some of the extra features of the other options.
Also, always lump related data together - if you use something as a cluster, make it a cluster. This will ensure that the entire kit'n'kaboodle gets written simultaneously, and will prevent you from reading half new and half old data.
Unread 08-03-2011, 16:08
We're using globals to communicate between teleop and periodic tasks, and to hold information to be sent in the dashboard data. I gave some thought to using other features such as queues or events, but I couldn't see a good way to pass the queue or event itself around without using a global variable anyway.
