Go to Post Too many hours of robotics and too little sleep causes me to forget things.... - AdamHeard [more]
Unread 09-03-2011, 10:45
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
To Brick or Not To Brick?
I've been watching several YouTube videos of the Granite State Regional and am curious to know why minibots are not using NXT bricks for control systems. I thought they were required. You're probably rolling your eyes at my question but if we don't need a brick, we'll use a direct switch to engage the motor. Sure will save weight as well.
To Brick or Not to Brick....that is the question!
Steve Miller
Team 3355
Unread 09-03-2011, 10:48
Sean1038 Sean1038 is offline
FRC #1038
Sean1038 is an unknown quantity at this point
Re: To Brick or Not To Brick?
I'm pretty sure they are not required.
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Steve Miller
Team 3355
They are not required, and teams are not using them because they add a lot of unnecessary weight to the minibot. This means a lot of time added to the climb due to the limited fixed source of power.
I don't have the link on hand right now, but this has been asked and answered on the Q&A. You should be able to find it there somewhere if you dig around the minibot section.
Unread 09-03-2011, 11:53
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
The NXT Brick adds unnecessary weight to the minibot.
Nearly all of the most successful minibots I've seen either use the Tetrix on/off switch or a series of small limit switches to turn the motors on and off.
-Dustin Benedict
Unread 09-03-2011, 12:13
DonRotolo's Avatar
Back to humble
FRC #0832
Note that the microswitches included with the KoP are "Limit Switches" - look on the manufacturer website.
Unread 09-03-2011, 13:44
maltz1881 maltz1881 is offline
maltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant future
So far, the only mini that I have seen using the NXT Brick is 3536. I am thinking we have convinced them to change that.
Unread 09-03-2011, 13:52
Nelson's Avatar
Nelson Nelson is offline
Lord of Engineering
AKA: Spock
FRC #3241 (Dragon Army)
Nelson is an unknown quantity at this point
With the opperation of the mminibot limited to turning on, going up a pole, and turning of, there is no reason to use anythig more complicated than an on/off switch.
Unread 09-03-2011, 13:58
Racer26 Racer26 is offline
The rules stated "No more than 1 NXT brick" indicating 0 as an option.
Unread 09-03-2011, 18:16
Alex Dinsmoor's Avatar
Alex Dinsmoor Alex Dinsmoor is offline
Are our seeding points over 9000?
FRC #0201 (FEDS)
Alex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant future
Send a message via AIM to Alex Dinsmoor
We used a NXT for our minibot for Traverse with great success. Although it wasn't the fastest, it worked consistently.
However we are going to rebuild our minibot without the NXT in order to save weight. We found that all the winning minibots didn't have an NXT.
'08, '09, '10
4 Years | 14 Competitions | 194 Matches | 119 Wins | 77 Losses | 2 Silver | 1 Gold
Unread 09-03-2011, 18:30
TEE's Avatar
TEE TEE is offline
FRC #0201
TEE has a spectacular aura aboutTEE has a spectacular aura aboutTEE has a spectacular aura about
AND we're keeping the first one, Alex
Unread 09-03-2011, 18:52
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Rule #1 of minibots: When building a new minibot, don't dismantle the first one until the second one works. We learned this lesson yesterday. Fortunately we got the new one working.
Rule #2 of minibots: Don't use the NXT brick.
Unread 09-03-2011, 18:56
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Change that Rule #2 into don't use a part you don't need. Every ounce/gram counts.
Unread 09-03-2011, 19:04
FRC #0201 (FEDS)
Sorry, my writings were hard to understand; I ment to say that we are building a second without the NXT.
'08, '09, '10
Unread 09-03-2011, 22:52
We have loaned out our 120t built minibot (just kidding on the number but it sure feels like we have built it that many times!) to 1 of our rookies for the weekend. I think we have finally discovered how to "redo" that transmission for the speed. We are going to put a sign on 1 side saying "see ya"! On the bottom side it will say "help me!"... I have a love/hate relationship with those things!
Unread 10-03-2011, 10:39
AKA: Steve Miller
Thanks to all the pearls o' wisdom. OUr team needs as many as we can get. For us, it's a tough game this year and our team is getting overwhelmed with multiple AP course loads. Typical Spring for robotics right? Thanks again...hopefully will see some of y'all at either the Oklahoma or Dallas Regionals
