Go to Post For some people FRC is an introduction into STEM and just a way to open someones eyes to a world they might not know exist. To other it is a lifestyle that makes crossfit look casual. - IronicDeadBird [more]
Unread 09-03-2011, 11:34
Haaris Haaris is offline
FRC #2872
Haaris is an unknown quantity at this point
Weights on the minibot
Are we allowed to put weights on the minibot in order to balance it out?
Unread 09-03-2011, 11:35
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
Re: Weights on the minibot
I'd assume so. Counting on they are made out of the allowed materials.
Unread 09-03-2011, 11:42
Hellfeier675's Avatar
Hellfeier675 Hellfeier675 is offline
FRC #0675 (Tech High Robotics Syndicate)
Hellfeier675 is an unknown quantity at this point
Just curious, how much does your minibot weigh?
-"Guys it's so inconvenient, Delphi is down at 3 am.... Hey I was bored last night!"
Unread 09-03-2011, 11:55
FRC #2872
What in the allowed parts list would be substantially heavy besides the battery?
Unread 09-03-2011, 12:10
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
First, I would strongly recommend balancing your weight using the weight (motors and battery) you already have...
Our minibot only uses magnets to secure itself onto the pole, so when the weight was initially off to one side we trimmed down the aluminum plate on the heavy side and moved the magnet mounts closer to the heavy side. We ended up with the motors about 1.5" away from the magnets and the battery .5" away on the other side, leaving us well balanced and capable of climbing straight up the pole!
It's best to remove or adjust weight to move CG where you want it... particularly since the minibot is a race! If you really can't adjust your design, then perhaps a small PVC tube filled with steel fasteners can help you out.
Best of luck!
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 09-03-2011, 12:17
It says in 4.3.14 <92> That you could use a NXT brick. Last time I checked they were kinda heavy. You could also use raw material listed in the parts list.
Unread 09-03-2011, 16:47
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Why would you ever want to add weight to your minibot? That would make it slower. The idea is to make it as fast as possible.
Battery, motors (gearheads removed), some sort of custom rollers, switches, maybe some magnets, and a stick to hold it all together. For the minibot, Minimal=win.
Unread 09-03-2011, 16:51
Ours weighs about 2.3 lbs, that's as light as we cold make it.
Unread 09-03-2011, 16:57
Chris is me's Avatar
AKA: Pinecone
Don't fix your minibot by adding weight. Move the battery.
You CAN add weight using legal materials, but it will not help your minibot time.
