Re: To Brick or Not To Brick?
So far, the only mini that I have seen using the NXT Brick is 3536. I am thinking we have convinced them to change that.
With the opperation of the mminibot limited to turning on, going up a pole, and turning of, there is no reason to use anythig more complicated than an on/off switch.
The rules stated "No more than 1 NXT brick" indicating 0 as an option.
We used a NXT for our minibot for Traverse with great success. Although it wasn't the fastest, it worked consistently.
However we are going to rebuild our minibot without the NXT in order to save weight. We found that all the winning minibots didn't have an NXT. |
AND we're keeping the first one, Alex
Rule #1 of minibots: When building a new minibot, don't dismantle the first one until the second one works. We learned this lesson yesterday. Fortunately we got the new one working.
Rule #2 of minibots: Don't use the NXT brick. |
#7
Sorry, my writings were hard to understand; I ment to say that we are building a second without the NXT.
#9
We have loaned out our 120t built minibot (just kidding on the number but it sure feels like we have built it that many times!) to 1 of our rookies for the weekend. I think we have finally discovered how to "redo" that transmission for the speed. We are going to put a sign on 1 side saying "see ya"! On the bottom side it will say "help me!"... I have a love/hate relationship with those things!
#10
Thanks to all the pearls o' wisdom. OUr team needs as many as we can get. For us, it's a tough game this year and our team is getting overwhelmed with multiple AP course loads. Typical Spring for robotics right? Thanks again...hopefully will see some of y'all at either the Oklahoma or Dallas Regionals
#11
Many a Motors has "smoked" this season in the quest for elevation and speed. The makers of the Textrix motors are feeling good about the sales figures I am certain. We have eaten 3 sets, but we did it just by running the snot out of them in testing.
There has also been many threads about the trigger shinanagins from the more than a few light weights not lifting the plates or timing off because the use of the simple switch forgot to put in some type of delay i.e spring or leader pin. Unlike alot of matches we saw, if our bot climbed past the 18" line the light was going off...no matter what pole...Period. If you are a rookie team that has limited funding, and the possibility of smoking a bunch of motors "before you get it right" is not a viable option. The NXT model isnt a bad move. Few can argue how robust our NXT Mini-bot was. It climbed even after some outragious hits. Now we do agree that the added weight is a speed issue. You will have to go slower when it comes to the gearing required to elevate the mass of the NXT style. The decision is not as cut and dry as some want it to be.....And you know what? That is what makes this fun. Last edited by Coach#3536 : 10-03-2011 at 23:49. Reason: not clear and to point |
