Go to Post Yes, I have already determined that the device is capable of launching 2,160 Krispy Kreme donuts into the back seat of my Mustang with a vertical displacement of 65 feet, without cracking the sugary glaze on a single donut. - dlavery [more]
Unread 09-03-2011, 17:16
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Batteries~
Hello we are prepping for our first regional and got some last min question.
How long does the kit charger take to fill a battery?
and how many batteries do you general need?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 09-03-2011, 17:39
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Batteries~
I would say three or four minimum (you MIGHT be able to do it with 2, but you will have to run some matches on a less-than-full battery), those that are not in use should be kept on a charger, use automated chargers that switch to float or trickle charge automatically.
As far as time is concerned, I'm not sure, but it depends on the current used to charge the batteries. Higher current = faster charge but fewer cycles so it should only be used if you have to.
Unread 09-03-2011, 18:40
Dale(294engr]'s Avatar
Dale(294engr] Dale(294engr] is offline
Mentor/Sponsor since '98
Dale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of light
Re: Batteries~
When 5A Quick Charge lamp goes out it is ~80% charged
Time to get there depends on the degree of discharge, batt age, temp
(SLA batts should ALWAYS be on charge to prolong life maintain lowest internal resistance = max delivered performance)
the 20% balance occurs in trickle mode usually ~.1A so takes 2-3hours..
Responding to earlier commenter. Quick charge does NOT reduce battery life
that's why it is programmed to cut off early (charge heating is culprit)
Battery life can be greatly extended (years) by charging ASAP after each use and remaining on trickle at all time
good news full top off is rarely needed
unless your robot draws above average current during 2m15s match
due to lots of robot pushing.. or inefficient drive train
cant have too many SLA's..
I advise my team to save least 1 Batt that had a full overnight trickle
for critical playoff use expect pushing matches of extra speed power
I will be RI at SanDiego & will bring Flash Drive with my Battery Workshop
I have Dynamic Battery Discharge curves that illustrate V vs I for constant load ~50A (18AH is valid only at .8A, at 50A it is a 6min batt! before the Vout drops quickly)
Unread 09-03-2011, 19:24
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Batteries~
A 6 Amp quick charge is not as good for the battery as a 2A slow charge. But, if you expect that your batteries will last only 2 or 3 seasons, it hardly matters.
It IS very important to always keep your batteries as fully charged as possible, since being in a discharged state causes irreversible damage (sulphation). Keep this in mind as you put them away after the robot season, especially over the summer.
Team 1676 brings ten batteries and six chargers to a regional, this is enough for qualification and eliminations all the way to the Finals. If you make it into the eliminations, I am sure several teams will be happy to loan you fully-charged batteries. Considering that, 4 or 5 should be plenty for a basic stock, with 2 or 3 chargers. 2 would be a bare minimum, but possible with care.
