Go to Post Understand the problem before trying to apply bandaids. You might not even be putting the bandaids in the right spot. - Bryan Herbst [more]
Unread 07-03-2011, 16:48
Daniel Ernst's Avatar
Daniel Ernst Daniel Ernst is offline
FRC #0469 (LasGuerrillas)
Team Role: Photography
Daniel Ernst has a reputation beyond reputeDaniel Ernst has a reputation beyond reputeDaniel Ernst has a reputation beyond reputeDaniel Ernst has a reputation beyond reputeDaniel Ernst has a reputation beyond reputeDaniel Ernst has a reputation beyond reputeDaniel Ernst has a reputation beyond reputeDaniel Ernst has a reputation beyond reputeDaniel Ernst has a reputation beyond reputeDaniel Ernst has a reputation beyond reputeDaniel Ernst has a reputation beyond repute
Photos - Kettering 2011
I have posted my photos from Kettering 2011 at
http://www.flickr.com/photos/daniele...7626218631340/
As usual, these are free for non-commercial team and personal use.
Please contact me for any other use.
Enjoy.
Unread 07-03-2011, 18:14
Mr.G Mr.G is offline
AKA: Kevin
FRC #0326 (Xtreme Eagles / Romulus High School / General Motors)
Mr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond repute
Send a message via AIM to Mr.G
Re: Photos - Kettering 2011
Very very cool shots.....Thanks for sharing.
Unread 07-03-2011, 23:01
Basel A's Avatar
Basel A Basel A is online now
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Fantastic as always!
A question: How much of a challenge was photographing the minibots? I had some blurriness issues (admittedly with shutter speeds too slow for an FRC competition), but your pictures from only a couple yards away from me (hence things like this) seem great.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 08-03-2011, 08:16
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Amazing shots Dan. Thank you so much for taking these.
Unread 08-03-2011, 09:25
Photographing the minibots was quite a challenge. They're fast and tiny, sometimes not much wider than the pole. Autofocus is the only thing fast enough to keep up, but it's often confused with what to focus on; the pole, the light at the top, or that barely noticeable blob racing up the pole. My "hit" ratio with minibots was much lower than with all other subjects. I did pick a spot on the pole and prefocus a few times, which worked out better sometimes, but I was often disappointed when the minibot I chose to cover didn't even make it up the pole, and another one next to it did, but I wasn't set up for it.
My suggestion is to shoot a little wider scene, focusing on the top of the pole, and shoot many frames. Also, if you have any leeway in shutter speed, you'll want to overexpose a bit as the meter usually picks up the overhead lights and underexposes the subject.
As for shutter speed, I usually shoot in aperture mode, wide open, and iso as high as I'm comfortable with (1600 ~ 2000), which usually yields an adequate shutter speed. But it's always a compromise. Depending on your lens, you may have to push iso higher and put up with some noise, or even underexpose. But that's just my personal preference. I'd rather see a slightly underexposed, noisy image with no blur, than a correctly exposed blurry one.
Unread 09-03-2011, 17:46
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Thanks for sharing, you have great talent.
Your watermark on these say copy write 2010...
Unread 10-03-2011, 05:50
That's me, living in the past.
Thanks for catching that. Happy new year!
