Go to Post Yes, it can. You'll have to ask the lawyers around here whether it's legal or not. - Kevin Watson [more]
Unread 09-03-2011, 18:19
Sb28000's Avatar
Sb28000 Sb28000 is offline
FRC #2656 (Quasics)
Sb28000 is on a distinguished road
Question Minibot pulling away from pole
Early on, we settled on a three-wheeled design, set at 120 degree angles to each other. However, we discovered (a bit late) that the third wheel, built on a pivot, would not maintain enough tension on the pole. Trying to come up with a new design, we thought of using basically trapping the pole between a length of Ttrix C-channel and the two powered wheels (that were parrallel to this bar). However, the minibot tended to pull away from the pole in the direction of the motors, and even with magnets we could not correct for this. We have since built something similar to Team 166's design, http://www.youtube.com/watch?v=ERVuEe9yytM
using four wheels, with two wheels driven from each motor. But we are still strugggling witht the minibot pulling away from the pole, backwards. If anyone could tell us if they encountered this problem or how they overcame it, we would appreciate it.
Team 2656
Pittsburgh Regional Finalists 2010
Hoping to come back strong in 2012!
Unread 09-03-2011, 18:24
Brandtlamonte Brandtlamonte is offline
FRC #2080
Brandtlamonte is an unknown quantity at this point
Re: Minibot pulling away from pole
Try and post a picture. All I can say is, limit the weight going away from the pole, use stronger magnets, etc. I'd show you mine, but my team doesn't want our idea stolen
Unread 09-03-2011, 18:29
Sb28000's Avatar
FRC #2656 (Quasics)
Our minibot is curently in our shop, waiting to be taken along to our regional tomorrow. Right not there is nothing balancing the weight of the motors, and by applying a small amount of pressure by hand, it seems to climb fine. However, sincce our current design only holds the pole between its wheels and not latch around it, we are unsure how we could place the battery to properly balance it.
Unread 09-03-2011, 21:05
FRC #2080
Balance it at the bottom (assuming your minibot is the same as ours) to tension the wheels against the pole, or on the outside edge. If that doesnt work, try a different spot. Are you using magnets? Our team used magnets and we were slipping, added more magnets - no slip
Unread 09-03-2011, 21:12
Sb28000's Avatar
FRC #2656 (Quasics)
Our current minibot does not have magnets attached; however, we previously had tried to use them. Currently, we were using a Tetrix axle at the bottom to allow the wheels to remain parallel to the pole, but it still continued to pull away. Thank you, we will try to put on some magnets tomorrow during the practice matches when we have time.
Unread 09-03-2011, 22:26
Matt704's Avatar
Matt704 Matt704 is offline
AKA: Matt Ricks
FRC #0704 (Warriors)
Team Role: Driver
Matt704 is on a distinguished road
Your axle may not be positioned in the right place. It probably needs to be lined up closer to the middle of the wheels.
Here is what we did originally. Hopefully you can see it, but since it is on facebook you may have to be friends our mentor who posted it to be able to see it.
http://www.facebook.com/video/video.php?v=1775071903972
Visit our You tube channel http://www.youtube.com/user/SGPHSRobotics
Team 704 warriors
2012 Dean's List Winner
2011 Dean's List Finalist
2010 Dean"s List Finalist
Unread 10-03-2011, 00:00
IKE's Avatar
IKE IKE is online now
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Keep tramming in the lower axle. It has a ton to do with efficiency and keeping the minibot on the pole. A little off will cause a lot of scrub and may cause it to eject itself.
Our architecture is derivative of the 166 youtube style bot. We literally built about 10 versions of it until we were satisfied enough for Kettering.
