Go to Post I've ridden the real Segway many times and I think it is a truly remarkable machine and worth every cent (if you have enough cents to spend on it). - sanddrag [more]
Unread 09-03-2011, 20:18
KevinGoneNuts's Avatar
KevinGoneNuts KevinGoneNuts is offline
AKA: Kevin
FRC #0675 (Tech High Robotics)
KevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud of
Re: pic: Team 675 2011 Robot CAD
Originally Posted by =Martin=Taylor= View Post
This design looks familiar
I don't know what you're talking about
What is the claw made out of? We made ours out of plywood, fiberglass, and chopped carbon fiber in '07; it was somewhat of a tour de force for our team at the time...
We made it by epoxying two pieces of hexel together. It's quite light!
Unread 10-03-2011, 00:58
Hellfeier675's Avatar
Hellfeier675 Hellfeier675 is offline
FRC #0675 (Tech High Robotics Syndicate)
Hellfeier675 is an unknown quantity at this point
Fixing your bumper problem should be simple if the claw will still work with the bumper there.
Just bolt another tube across the front to provide "frame backing" and you'll be good.
GL in Sactown!
That's where we got some of our inspiration from
Like Kevin said, we epoxied two pieces of 1/4" plywood together and epoxied the outer rim to stabilize it. There are parts where we glued c-channel to the outside to prevent damage, but overall we expect it to be strong enough
We had a second damaged one without the siding or extra epoxying and one of the claw "jaws" held 50 lbs of downward force by itself before it gave way
In reply to your bumper fix, I guess great minds think alike That's what we did today once we realized that we had skipped over a crucial rule, seems to have worked well enough on our practice robot!
See you at Sac!!!
-"Guys it's so inconvenient, Delphi is down at 3 am.... Hey I was bored last night!"
Unread 10-03-2011, 10:23
See you at Sac!!!
Hexcell***
Not plywood sorry!! xD
I'm curious for your claw this year, we saw the CAD but are still baffled
Unread 01-01-2012, 22:20
Andrew Lawrence
Posts: n/a
What kind of wheels are those? I know you've used mecanums in the past, but the render makes it hard to tell.
Also, anyone know how much it weighed? Looks light.
