Go to Post I can still remember how weird it was to look on the other side of our booth and see a kid in a suit tossing purple balls... - OneAngryDaisy [more]
Unread 13-11-2002, 11:32
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
SPIKE relays
Has any one else noticed that the Innovation FIRST website only shows the RED Spike relays?
This changes the wiring diagram compared to the spikes we received the last two years. The solenoids will now always be 'HOT' (12v+).
The BLUE spikes are still available from IFI.
Unread 13-11-2002, 12:27
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
??? The only difference is a built in 10% dead zone, which is best for FIRST because 10% won't move a bot
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 13-11-2002, 13:22
Matt Reiland's Avatar
'The' drive behind the drive
The dead zone apply's to the Victors, I think it was the red 884 was for arm positioning without the Dead zone
The spike wiring for red and blue should be in the manual, here it is:
The “red” Relay Modules connect the M+ and M- outputs to +12 Vdc when in the off state. The “blue” Relay Modules connect the M+ and M- outputs to Ground when in the off state. On both
types, M+ is connected to +12 Vdc and M- is connected to Ground when the Relay Module is in “Forward” mode, and vice versa for “Reverse” mode. Normally, the Relay Modules are connected
across both leads of a DC motor, which means that both types provide equivalent bi-directional motor control. However, it may be desirable to utilize the M+ and M- outputs to independently
control simple on-off devices or motors which only need to run in a single direction, in order to reduce the number of Relay Modules needed. If independent control of two devices is to be used, the wiring must be based on the type of Relay Module.
The spike will have 12V at both terminals with no 'potential' between them thus the the solenoit will not shift
Spike RED Pinout Venkatesh Electrical 3 31-03-2003 21:42
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
spike great_one411 Electrical 2 06-02-2003 09:10
Spike Relay Input nwagers Electrical 3 16-07-2002 22:23
How do you control relays BinaryBob0001 Technical Discussion 2 21-01-2002 08:42
