Go to Post The imperfect COTS parts you have in your shop will perform much better on the competition field than the perfect custom parts you only have CAD drawings for. - philso [more]
Unread 10-03-2011, 16:25
Straberrie's Avatar
Straberrie Straberrie is offline
The Plague
AKA: Rebecca
FRC #0375 (Robotic Plague)
Straberrie will become famous soon enough
Voltage not displaying on Classmate
Hey everyone,
Last time we tested out robot before ship date, the voltage was not outputting on the classmate screen.
The voltage on classmate displayed "0.00" the entire time.
The robot communicated with the classmate; the classmate recognized the joysticks. We ran code and everything worked correctly. I had the latest driver station update and the latest Crio image, I double-checked.
I was also running the radio in access point mode and communicated wirelessly with the classmate, without using an extra router.
Any ideas?
Thanks!
Team 375: The Robotic Plague
Current Robot: I-Chihuahua
Last Event: Big Apple Breakaway
Unread 10-03-2011, 16:28
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Voltage not displaying on Classmate
make sure you have a jumper on the analog breakout board, on the two pins at the very very end (away from the power, don't remember what they say off the top of my head)
Watchdog.Kill();
Unread 10-03-2011, 16:36
CoachPoore CoachPoore is offline
AKA: Noel Poore
FRC #1519 (Mechanical Mayhem)
CoachPoore has a spectacular aura aboutCoachPoore has a spectacular aura about
Send a message via AIM to CoachPoore
Make sure you have power connected to the analog breakout board and the green power LED on the board is on. Also, check that you have a breaker in the right spot on the power distribution board. Don't ask me how I know this
Noel
2011 Granite State Regional Winners with teams 175 and 176
2010 Granite State Regional Winners with teams 1073 and 1058
2010 Granite State Regional Innovation In Controls Award Winners
2010 North Carolina Regional Engineering Excellence Award Winners
2010 North Carolina Regional Finalists with teams 1772 and 1741
Unread 10-03-2011, 16:41
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
This is the voice of experience. Once you have verified that the jumper is in place and have verified the Analog breakout is powered, verify that Analog input #8 is not called or used anywhere in your code.
Unread 10-03-2011, 20:47
Check for loose wires from the PD to the analog breakout -- use a multimeter to check the voltate at the module. Also, verify that the analog module is in slot 1.
Greg McKaskle
Unread 10-03-2011, 16:34
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
The most common cause of this problem is a lack of power to the analog breakout card. Check to confirm that the LED on the analog breakout is lit. If the LED is not lit, check the power wire to the PDB and the circuit breaker in the PDB.
The second most common cause (as mentioned by byteit101) is to ensure that the jumper on the analog breakout card is correctly positioned.
I would note that having voltage correctly displayed on the classmate is a requirement to participate in practice matches at regional events, so you'll want to fix this ASAP when you get to your first event.
Are you using any analog inputs on the analog breakout?
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
