Go to Post Gravity is not always pointing the same direction relative to the robot! - ChrisH [more]
Unread 11-03-2011, 11:15
johncap100 johncap100 is offline
FTC #0658
johncap100 is an unknown quantity at this point
solenoid
Hello I have attached a simple autonomous Indep vi to control a solenoid. The solenoid activates during the code. I would like to add the stop signal in the code so I could stop the solenoid. If someone could look at it I am sure it is quite simple for experienced people. I am a neophyte at this stuff.
thanks John science teacher and FRc team coach
Unread 11-03-2011, 11:18
FTC #0658
Re: solenoid
oops forgot to attach here it is
Unread 12-03-2011, 23:18
Re: solenoid
Not sure what you mean by the stop signal, how you expect it to be operate, or what you expect to happen.
Unread 13-03-2011, 00:31
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: solenoid
Although this won't impact your code, hopefully you're thinking of a solenoid-actuated pneumatic valve ("solenoid valve"), and not merely an electric solenoid actuator (often shortened to "solenoid")? The latter are inexplicably illegal in FRC.
