Go to Post She must have known that if she declined the invitation to form an alliance that no one else would be allowed to pick her. (But of course, as any happy husband knows... the wife is always the #1 seed!) - dtengineering [more]
  #31   Spotlight this post!
Unread 11-03-2011, 09:17
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Will we see a wall robot?
<G32> Neither ROBOTS, HOSTBOTS, nor MINIBOTS may break the planes of the vertically
projected borders of the opponent‟s ZONES, including a GAME PIECE in their
POSSESSION. Momentary incursions by a POSSESSED GAME PIECE will not be penalized
if they do not make contact with anything in the ZONE.
Violation: PENALTY. G61 does not apply to this rule, however strategies aimed at taking
advantage of this exception will result in a PENALTY plus a YELLOW CARD. If a ROBOT
enters the opponent's ZONE and does not make immediate effort to leave OR if it contacts
another ROBOT (or GAME PIECE in its POSSESSION) also in the ZONE, then the intruding
TEAM will receive a RED CARD.
There is a rule that states if you do not attempt to move out immediately you receive penalty and a yellow card.
  #32   Spotlight this post!
Unread 11-03-2011, 14:08
Anyone have match videos of the other mentioned robots? I really want to see how a match ends up with that much blocking.
We will be very careful in out defense. Playing D during the end game and near end zone will be risky.
The amount of times we'll raise/lower the wings will be kept at a minimum. With the smaller compressor we have, and since we had to cut back two reservoir tanks, the battery drops below our optimal operating voltage if it fills the tanks more than a few times.
  #33   Spotlight this post!
Unread 11-03-2011, 20:39
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Will we see a wall robot?
What drive system are you using on your robot?
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
  #34   Spotlight this post!
Unread 11-03-2011, 20:49
4wd 8" AM plaction wheels with roughtop tread direct driven by toughboxes. It's nothing significant, but I hope it will be enough for what simple things we are doing. The wings have the same wheels with wedgetop tread. We should be running around 11fps I think? (I wasn't the one who ordered the Toughboxes so I'm not sure what reduction we ordered).
  #35   Spotlight this post!
Unread 11-03-2011, 21:13
Hodge1
You're not having difficulty turning?
Sweat the details
  #36   Spotlight this post!
Unread 11-03-2011, 21:18
In the open configuration it definitely won't turn. With the arms up, our wheelbase is still a little too long, so we don't do 0 point turns that well, arch turns are fine though.
  #37   Spotlight this post!
Unread 11-03-2011, 22:08
Jonzki's Avatar
Jonzki Jonzki is offline
FRC #3481 (BroncBotz)
Jonzki will become famous soon enough
Originally Posted by pwnageNick View Post
Imagine them on the alliance at alamo with 16 and 148, although 3553 cant score an ubertube, it wouldn't matter because 148 would score it for them. Then 16 and 148 would score like crazy like they did while 3553 held the other alliance to 0 points. I think Einstein's going to be exciting this year
And what was the scenario at the alamo?
2011 Season
FRC Team 3481
FTC Team 4008/4602
FLL Norway 2004-2008
FTC Team 3359, 2009/2010
  #38   Spotlight this post!
Unread 11-03-2011, 22:45
vigkvagkv2's Avatar
vigkvagkv2 vigkvagkv2 is offline
Dignitary Communicator
AKA: Raymond Lindberg
FRC #1778 (Chill Out!)
Team Role: Communications
vigkvagkv2 is an unknown quantity at this point
I highly doubt the robot inspectors would allow for a net since it's way too much of a tangle risk with other robots. I can easily see a robot manipulator getting into a hole or even a fold in the net, try to turn, and getting horribly stuck together.
Everything is possible. Some things are just harder to do than others.
  #39   Spotlight this post!
Unread 14-03-2011, 11:48
Shiplee Shiplee is offline
FRC #3528
Shiplee is an unknown quantity at this point
I thought I would chime in here considering our robot is being talked about lol
My name is Jordan and I'm one of the Team Captains from Team 3528. As a rookie team this year we wanted something that would be easier to design and control. I think we chose the right path.
The KC Regionals just finished up and we did pretty well I think, ontop of being chosen onto a top 8 alliance, we also walked away with the Rookie All Star. Just to let you know a little about our robot: 4 omni wheels and two plaction wheels on each of our wings, we were only able to be pushed around by one team and even then we held them pretty tight. When going up against teams that could put up two full logos when we aren't on the field, we held them to about one. I feel we were very very successful in our rookie year! plus, WE'RE GOING TO ST. LOUIS!
Woot woot
  #40   Spotlight this post!
Unread 14-03-2011, 16:51
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Woot woot
I've been playing with an idea that may work for your robot. Play D on the pegs for the first minute. Then deploy something that wraps around their tower preventing them from getting to their tower.
Congrats on the awards!
  #41   Spotlight this post!
Unread 14-03-2011, 17:20
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
not legal. Check out the rules for touching the opponent's tower in the endgame.
2001-2004: Team 100
2006-Present: Team 254
  #42   Spotlight this post!
Unread 14-03-2011, 17:24
mwtidd's Avatar
AKA: mike
Who said anything about touching it ?
I foresaw putting down wings with rubber bases that would brake if pushed against keeping space between you and the tower.
  #43   Spotlight this post!
Unread 14-03-2011, 17:32
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
What about breaking the plane of your opponent's LANE? Kind of have to do that if you want to wrap all the way around...
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
  #44   Spotlight this post!
Unread 14-03-2011, 17:41
mwtidd's Avatar
AKA: mike
Sorry, yeah I didn't clarify this. Imagine a candy cane, thats what it would look like. Forcing them to deploy from within their lane would significantly handicap many robots. It would slow down their deploy them, and make them start moving for deployment earlier. Teams that cap til the last second would probably have to sacrifice a tube or 2 for a minibot.
I saw the hook of the cane blocking teams from accessing the tower from the narrow slot, and then blocking a good portion of the lane.
So if you were able to keep a robot to 1 logo, and then handicap their deployment, it may boost your value significantly
  #45   Spotlight this post!
Unread 14-03-2011, 18:11
Cory's Avatar
AKA: Cory McBride
Until you get red carded when robots slam into you and your "wings" end up touching their tower.
2001-2004: Team 100
