#9
Re: Rookie Team 3729's minibot
Each motor armature has a two inch long 3/8 diameter extension. The extensions are covered in latex tubing and drive directly on the pole. The minbot frame is 8 inch by 3 1/2 inch 1/16 thick Lexan. There are two pieces of 6 inch long 1/2 inch aluminum tubing attached to the frame that guide the minibot off the deployment tray. The only other components are two lamp switches and the Tetrix battery.
