Go to Post I think these new rules are making the message coming from FIRST perfectly clear - engineering is about what happens between your ears, not what comes out of your deep pockets. - KenWittlief [more]
Unread 12-03-2011, 00:05
Biolore Biolore is offline
Lead Programmer
AKA: Josh
FRC #3597 (Robo-Rangers)
Biolore is infamous around these partsBiolore is infamous around these parts
Airsoft gun Clip modification
So, I've got a firepower A47 Beta (http://www.airsocom.com/47390B6.html), and the crank for the clip broke. The shaft that it would plug into fits a 3mm allan wrench perfectly. I want to mount a small motor that can run the gear to load the airsoft gun while I hold the trigger. I'm Not sure where to get one, and that so far is my only problem
The motor would be around 120 rpm speed I think, and a somewhat low torque so it doesn't break the clip, likely with an either a keyed axel that can hook up to the proper allan, or a 3mm hex axel.
I figure this is the best place to ask.
Unread 12-03-2011, 00:08
Lead Programmer
AKA: Josh
Re: Airsoft gun Clip modification
Also, I would probably run it off of AA batteries or 9volt probably
Unread 12-03-2011, 10:40
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
A 6 volt black and decker screwdriver has about that speed and a .25 inch hex output, however, it might have a bit too much torque, Also, it is large but most of the casing can be removed easily.
The price here is $22 but Last year I bought 3 for ~12 dollars each at target and ~$10 at walmart.
http://www.blackanddecker.com/power-tools/AS600.aspx
Unread 25-03-2011, 21:32
Matt Howard's Avatar
Matt Howard Matt Howard is offline
Submarine Sailor
FRC #1622 (Spyder)
Matt Howard has a spectacular aura aboutMatt Howard has a spectacular aura aboutMatt Howard has a spectacular aura about
It's a MAGAZINE, not a clip. I got this beat into me in boot camp. Clips are used to strip load a weapon. Magazines are inserted into a weapon. Just thought I'd pass that along.
-2010 Las Vegas Regional Judges Award
-2010 Las Vegas Regional Safety Award
-2010 San Diego Regional GM Industrial Design Award
-2010 San Diego Regional Excellence in Design Award
Unread 27-03-2011, 01:47
nitneylion452's Avatar
AKA: Joe Lee
This is my rifle and this is my gun. This is for fighting, this is for fun.
