Go to Post I predict the champion drive teams at each event of the 2011 season will consist of vertebrates. - Taylor [more]
Unread 10-03-2011, 20:16
jeleser's Avatar
jeleser jeleser is offline
AKA: Justin Eleser
FRC #2080 (Torbotics)
jeleser is just really nicejeleser is just really nicejeleser is just really nicejeleser is just really nice
Clouded camera lens?
The black rotating piece that adjusts the focus on the camera for our robot was recently broken and wouldn't attach. We superglued it back on, and a bit of residue was lining the outer edge of the lens. Somebody saw this and tried to clean it (I'm assuming by wiping it with a cloth), and the residue was spread across the camera lens. We tested the camera and it's virtually useless unless we can clean the lens. We tried rubbing alcohol, and have yet to test the image, but the lens looks too covered with the residue for that to have worked. Somebody recommended trying Goo-gone, is there any potential for that to damage the lens?
Team 2080 Torbotics
2010- General build, Pit scouting
2011-2012- Electronics/Programming, Driver
2013- Electronics/Programming, Drive Coach
Unread 10-03-2011, 20:34
Andrew Lawrence
Posts: n/a
Re: Clouded camera lens?
Our camera broke too!
Unread 10-03-2011, 20:39
WileyB-J's Avatar
WileyB-J WileyB-J is offline
4976 Georgetown Rebels
FRC #4976 (Rebels)
WileyB-J will become famous soon enoughWileyB-J will become famous soon enough
little bit of gasoline on a q-tip might work
Unread 11-03-2011, 03:46
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Bad idea.
super glue is dissolved by acetone/aka nail polish remover.
you can use that to clean off.
not that not all nail polish removers are acetone(no odor ones are not acetone)
hope this helps.
-Borna Emami
Team 0x27
Unread 11-03-2011, 10:01
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Whatever you use to clean the glue off might dissolve the plastic parts.
Is the lens a standard small security camera lens? if so you might find a new one pretty reasonable...might take several days to get it though.
http://www.supercircuits.com/Camera-Lenses/
Unread 11-03-2011, 12:40
team 3311 team 3311 is offline
FRC #4057 (Klamath Basion Robotics)
team 3311 has a spectacular aura aboutteam 3311 has a spectacular aura about
Nail polish remover should work fine. Just aplie it with a qtip to reduce the chance of spreding it on place where you don't want it
Unread 11-03-2011, 14:32
Acetone dissolves many plastics.
Unread 11-03-2011, 21:54
WileyB-J's Avatar
FRC #4976 (Rebels)
Aha, im not talking about an arsonists amount of gasoline, but just a dab on the end of a qtip should work. (unless you're shaking like a hooker in church)
Unread 11-03-2011, 22:02
From wikipedia:
Acetone, which is commonly found in nail polish remover, is a widely available solvent capable of softening cured cyanoacrylate. Nitromethane is also an excellent solvent. Dimethyl sulfoxide can be used as solvent too. Methylene chloride is the most effective solvent, but is toxic. Gamma-butyrolactone is also effective at removing cured cyanoacrylate, and has low toxicity.
Methylene Chloride is found in many paint-stripping products. Read the label to find out.
Unread 12-03-2011, 01:34
jeleser's Avatar
AKA: Justin Eleser
From wikipedia:
I'll be sure to check our bottle of nail polish remover when we get back on Monday. Thank you all for the suggestions, I think that if the nail polish remover doesn't have Methylene Chloride we'll go ahead and try that.
Team 2080 Torbotics
Unread 12-03-2011, 07:50
Guys, the lens in the camera is a hard plastic material and acetone or other solvent is just going to make things worse. The lens does screw into the mounting that is attached to the pickup as I remember. I have seen lenses for sale that would fit this. However, you must replace with an identical part to remain legal.
Unread 12-03-2011, 09:02
You can purchase lenses from companies such as Edmunds Optics. But I'd suggest finding a team with a fried camera and salvaging the lens. You may want to put some Teflon tape on the threads to keep the lens from vibrating within the housing.
Greg McKaskle
Unread 12-03-2011, 14:25
...you must replace with an identical part to remain legal.
Why is that? I don't think the camera is covered under the rule that prevents modification of motors or control system components. It isn't even necessarily a KoP part.
Unread 18-03-2011, 13:56
J.Warsoff's Avatar
J.Warsoff J.Warsoff is offline
BECAUSE SCIENCE
AKA: Jared Warsoff
FRC #1676 (The Pascack PI-oneers)
J.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond repute
try using glasses cleaner (liquid solution and soft cloth). Worse comes to worst, just replace the lens.
"I reject your reality, and substitute my own!" -Adam Savage
Check me out on Twitter or Facebook
Acoustical Engineering & Music major at the University of Hartford / Hartt School of Music Class of 2017
Unread 18-03-2011, 14:01
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
I've never actually tried this...
However, have you considered the chemicals used to 'polish headlights' and remove the haze and yellow from them?
There's a possibility you'll be able to buff off the damage with that.
However, if there's a coating on there...like they use on eyeglass lenses you'll ruin it doing this.
Best of luck...
