Go to Post Competitions are won or lost far away from witnesses, ... In those long hours, is where we find inspiration in ourselves. For what inspires is not another's feats, but realize we have the power in ourselves to achieve that feat. - Mark Sheridan [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.50 average. Display Modes
  #181   Spotlight this post!
Unread 21-02-2011, 22:45
Tobot Tobot is offline
AKA: Toby
FRC #1827 (Robojackets)
Tobot is just really niceTobot is just really niceTobot is just really niceTobot is just really nice
Re: Minibot climb rate
We are flirting with 3.5 second climbs on a fresh battery.
http://www.flickr.com/photos/ukweli/5466703933/
  #182   Spotlight this post!
Unread 02-03-2011, 12:56
Generator of Entropy
FRC #2973 (The Mad Rockers)
Originally Posted by Jared341 View Post
That is exactly what we did (using only an inexpensive mill and lathe and a dremel), and it works great.
We were able to modify the Tetrix gearbox with no special tools / machines - we just had to stake the ID of the large gear to get it to press on to the top of the output shaft at the position of the gear attached to the brass gear
  #183   Spotlight this post!
Unread 12-03-2011, 01:47
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
What was the resulting gear ratio? And what does "stake the ID mean"?
TIA
  #184   Spotlight this post!
Unread 12-03-2011, 04:41
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
TIA
If you look at the output shaft you'll see that in the area where the gear is pressed on the shaft is "knurled" or has ridges formed in it to create the press fit. So I assume he means that they used a chisel or punch to deform (stake) the ID (inside diameter) of the gear so it will press on the un-knurled portion of the shaft where it will mesh with the input gear.
The mod of making the first gear mesh with the gear on the output shaft results in a 10.4 to 1 ratio instead of the factory 52 to 1.
Another way to accomplish this IF you have a lathe is to machine a spacer that fits on the output shaft between the gear and case so that it meshes with the input gear. On the motor end of the output shaft you need to turn it down the same amount as the length of the spacer so it will fit in the case.
In addition to increasing the output speed ~5x it reduces the drag in the trans aprox 50% by removing 2 gear interfaces. Make sure you don't loose the spacer on top of the input gear and remove the spacers on the other shaft, there is a small one on the shaft under the 25:10 gear.
  #185   Spotlight this post!
Unread 12-03-2011, 16:08
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Why keep that silly gearbox? Take it all the way off, and you can be seeing times in the 1.4-1.8 range. Most of the gains are due to the loss of weight of the huge wheels, and the gearboxes, not the raising of efficiency.
  #186   Spotlight this post!
Unread 12-03-2011, 17:05
pfreivald's Avatar
AKA: Patrick Freivald
That is fundamentally untrue, and easy to demonstrate as untrue.
Our current minibot is in the 1.8 second range (and very consistent, thank you), and even when we add excess weight just to see what it does with it, it's still faster.
Reducing weight matters, but increasing efficiency matters a whole lot, too. It's not a dichotomy, here -- both are important!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #187   Spotlight this post!
Unread 12-03-2011, 17:37
AKA: Simon Bohn
Thanks for proving me wrong. I was just inferring, so apologies, and I learned something!
  #188   Spotlight this post!
Unread 14-03-2011, 22:45
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I know it's not fast, but it's reliable. We are thrilled it is ready for Sacramento.
http://www.youtube.com/watch?v=AVx7oFAyfjg
  #189   Spotlight this post!
Unread 22-03-2011, 11:46
ngoc0623 ngoc0623 is offline
FRC #1754
ngoc0623 is an unknown quantity at this point
in order to climb the pole, you dont need the wheels and with this you can cut the weight of the minibot. Just suggesting.
  #190   Spotlight this post!
Unread 27-03-2011, 11:10
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
We were consistently getting ~1.2 seconds. We got our minibot measured by team 1279 at the DC regional and got a higher accuracy measurement:
Our deployment arm, when it was working properly , was taking ~0.2 seconds to get the bot on the pole, so total time was ~1.27 seconds.
Below is a photo of the bot, which uses a cnc machined chassis. Our goal was to use only the minimum of materials necessary to hold the components in place. Weight came in at 2.5 lb.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
  #191   Spotlight this post!
Unread 30-03-2011, 21:25
WileyB-J's Avatar
WileyB-J WileyB-J is offline
4976 Georgetown Rebels
FRC #4976 (Rebels)
WileyB-J will become famous soon enoughWileyB-J will become famous soon enough
meet richard.
not the fastest liger in the forest but hes around 2.2s and stupidly reliable.
it seems like its one of the most machined minibots out there!
  #192   Spotlight this post!
Unread 30-03-2011, 22:00
theschell theschell is offline
FRC #0768
theschell is an unknown quantity at this point
our mini bot helped us get up the pole in under 2 seconds with deployment so that got us back to back wins
2011 chesapeake regional winner
  #193   Spotlight this post!
Unread 30-03-2011, 22:24
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
I know 968's minibot is exteremly fast. They get like .7 seconds with the dployment. Well that is what was said, but if you saw it in really time their minbot was up when the clock still said 9. This minibot helped them win the LA regional. their minibots somewhere around a one seconds minibot.
2014 Colorado Regional Winners (Thanks 3310 and 2543)
2013 San Diego Regional Winners (Thanks 987 and 254)
2013 San Deigo Regional Entrepreneurship Award
2012 Los Angeles Regional Semifinalists (Thanks 599, 3309)
2012 San Diego Regional Finalists (Thanks 399, 2339)
2011 Los Angeles Regional Chairman's Award
2011 BAE Regional Judges Award
  #194   Spotlight this post!
Unread 30-03-2011, 22:46
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
Thats prety impressive. If you don't mind, what roller size did you use?
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
  #195   Spotlight this post!
Unread 31-03-2011, 06:28
None #0612
The axles are 3/8" aluminum, drilled to fit the motor shaft (we removed the spiral gear). The "tires" are 1/2" OD surgical tubing.
