Go to Post I have way too much time on my hands. - Brandon Martus [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 12-03-2011, 21:07
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: 2CAN API
Hmm... looks like there isn't anonymous access to the repository.
I posted the source on our website...
http://www.crosstheroadelectronics.com/2CAN.htm
Download Wind River Kernel Module Plugin Source (SVN rev 66) for FRC cRIO (Posted 3/12/2011) and import the project into Wind River. Then you can build the FRC_2CANPlugin.out that normally goes in the cRIO's FTP server.
Take a look at C2CAN::receiveMessage and C2CAN::sendMessage. Specifically how STo2CAN_TxCANPacket and STo2CAN_RxCANPacket are used.
Also I invite you to take a look at the C# example at...
http://www.crosstheroadelectronics.com/Cross_link.html
...for using a 2CAN to control Jaguars with non-FIRST firmware. With this you can drive your robot with just your PC/laptop/driverstation/net-book and connection to your 2CAN (Ethernet or Wi-Fi).
Plugin update for 2CAN ozrien CAN 3 01-02-2010 16:26
Wierd program behavior with LabVIEW and 2CAN Jon236 CAN 7 01-02-2010 15:55
2CAN Plugin Released Mike Copioli Control System 16 24-01-2010 03:31
Legality of the 2CAN Geek 2.0 FRC Control System 9 19-01-2010 20:51
SMTP C++ API Ryan M. Programming 1 23-09-2004 13:49
