Go to Post As usual this was the programmers fault. - Swampdude [more]
Unread 13-03-2011, 00:07
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: How are <1.5 sec Minibots doing it ? Gearbox mods allowed ?
Originally Posted by Chris is me View Post
Tetrix shafts are too small, go bigger.
less is more when it comes to output diameter and force.
Unread 13-03-2011, 00:27
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Now this is where it confuses me, we purposely left our modified motors at our shop and used our unmodified minibot (got us really far) but apparently we had to sign a paper that stated we would not modify the gearbox. What was with that? I asked th inspectors, they said it was not allowed and said gracious professionalism should be kept. The inspectors never checked the minbots for modified gearboxes.
Unread 13-03-2011, 00:30
Chris is me's Avatar
AKA: Pinecone
This is blatantly incorrect. You are allowed to modify the gearboxes but not the motors. Anyone who said otherwise just doesn't know the rules.
Unread 13-03-2011, 00:38
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Thank God. I don't know, our mentor, team captain and anyone with "authority" blantantly said "no David, no". Now for LA we are just making our MB super fast. Honestly though, we had a very very reliable deployment and minibot. (11:15 made to attempted ratio) It was slow, but that got us to Semi Finals and apparently we ended the competition at rank #4. I am impressed.
Unread 13-03-2011, 00:51
AKA: Pinecone
A slow minibot that makes it every match made our #6 spot on our pick list (maybe a little lower, I don't have it). It's all about consistency.
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Is very, very reliable 11:15? Less than half?
We haven't gone to an actual competition yet, but we've never failed in deploying - obviously, it will be different with all of the other robots flying everywhere, but still. What was yours like during testing?
Unread 13-03-2011, 01:03
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Honestly, it was fail proof, but not human proof. It is programmed that the robot backs up into the pole as it deploys so it is guarantee that it deploys. The 4 were human errors such as forgetting to put the deadman switch on or driving away from the pole as it deployed or going to the pole too late(we just get pushed around) But it makes it every single time as long as we set up around 25 sec. But we did not choose to use the arm (we zip tied it to the robot), so we went defensive (because of our design flaw, that was our down fall) then deploy every match.
Edit: that was not the gear ratio, I am saying reliability > speed. We had a 4 second minibot
Edit: that minibot alone got us to the #3 spot (we dropped down to #4 when we DQed for getting pushed into the scoring zone by the other robots several times at the semis)
Unread 13-03-2011, 10:02
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
Speed does play a huge factor once eliminations hit. We were on the number 5 alliance going against the number 1 alliance. We had one minibot, they had 2. The only way we could win was to get our minibot up first and let them score 2 and 3. We also had to outscore them on tubes. We beat them. While reliability is what gets you picked. Fast minibots get you a win.
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
Unread 13-03-2011, 01:06
The Lucas's Avatar
CaMOElot, it is a silly place
You can always modify any gearbox unless the rules (or Q&A) specifically states you cannot modify it because it is integral. Currently, the only legal modification you can make to the Denso window motor gearbox/motor is removing the pins (all other mods illegal, however you can do this). All other gear boxes are fair game for mods.
Robot Inspector
Unread 13-03-2011, 12:20
AKA: Alan Wells
FRC #1350 (Rambots)
No, you cannot do that with a desno motor,
http://forums.usfirst.org/showthread.php?t=17054
however, the motor/gearbox combo photo is still legal due to this.
Unread 13-03-2011, 17:04
jtechau jtechau is offline
AKA: Jeff Techau
FRC #1388 (Eagle Robotics)
jtechau is just really nicejtechau is just really nicejtechau is just really nicejtechau is just really nice
The lesson to be learned here is that if you're doing anything that relies on interpretation of the rules or a Q&A clarification, make sure you do your homework, and bring a printout of the relevant rules / Q&A to show the inspector. In fact, make yourself familiar with all the rules. Be prepared to present the facts to the inspector; but don't try to argue with them - that will generally work against you. Remember gracious professionalism.
I recently had such a conversation with an inspector regarding the playing configuration size. He claimed that it included bumpers, which would not have worked for us. Fortunately, I was able to point out the rule section that clearly stated bumpers are not included in playing configuration size, and all was well.
Unread 13-03-2011, 17:38
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Hello sir, we will see you at Long Beach. Good luck to you guys and be prepared. We will be prepared to dominate the West Coast.
Unread 13-03-2011, 18:39
Generator of Entropy
FRC #2973 (The Mad Rockers)
And I'm pretty sure that the GDC knows the rules
http://forums.usfirst.org/showthread.php?t=16779
Unread 27-03-2011, 14:44
Free Willy's Avatar
Free Willy Free Willy is offline
Free Willy is an unknown quantity at this point
Can someone post a picture of a modified gearbox? Thanks!
Unread 28-03-2011, 14:27
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Here is a pic of un-modified transmission.
The way you modify it to become a 10.4 to 1 can be achieved in a couple of ways. All of them involve removing the 30:15 and 25:10 gears and mating the 26:10 to the 40t output gear.
The way we did it was to machine a spacer that fits around the output shaft and raises it to the proper position to engage the 10t on the 26:10 gear. Then we machined the end of the output shaft you can see in the pic the same amount so the end plate fits back on with the proper end play.
A team we gave our spare minibot pieces to in Seattle knurled the output shaft so the 40t gear could be pressed up the corresponding amount. In the picture you can barely see the knurling on the output shaft where the 40t gear is pressed on.
I have also read on here of 2 other ways. #1 removing the gear and staking it around it's ID to reduce that diameter, then pressing it back on with thread locker as a little extra insurance. #2 shorten the case, and swap the existing spacers around, use the one that is under the 25:10 under the 26:10 and the one that came off the top of the 26:10 on top. This method also requires shortening the output shaft so the case fit's back together. This method is the most complex.
So there are a number of ways to skin this cat depending on the tooling and skills your team has.
